Home » Eclipse Projects » GEF » Custom Property Sheet page
Custom Property Sheet page [message #248455] Tue, 21 April 2009 06:54 Go to next message
Originally posted by: massimiliano.ziccardi.gmail.com
Hi all.
Do someone knows how to associate a custom property sheet page to an
edit part?
I found some documentation on the net, bu everything seems quite
outdated....
Thank you all,
Massimiliano
Re: Custom Property Sheet page [message #248460 is a reply to message #248455] Tue, 21 April 2009 08:13 Go to previous messageGo to next message
Originally posted by: cayla_sha.gmx.net
Hello!
This is a very interesting and not outdated article:
http://www.eclipse.org/articles/Article-Tabbed-Properties/ta bbed_properties_view.html
I think, this is also helpful:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/extension-points/org_eclipse_ui_v iews_properties_tabbed_propertySections.html
You have to define a filter for all of your sections.
If you don`t know how a filter should look like, look at:
org.eclipse.gmf.runtime.diagram.ui.properties.filters.Diagra mEditPartPropertySectionFilter
Have fun!
Julia
Massimiliano Ziccardi schrieb:
> Hi all.
> edit part?
> outdated....
> Thank you all,
> Massimiliano
Re: Custom Property Sheet page [message #248474 is a reply to message #248460] Tue, 21 April 2009 10:11 Go to previous messageGo to next message
two additions:
- you could also define one or more "input types" for each property
section. The type is a class or interface that the selection must match
for the section to be displayed on the tab.
- let your property sections inherit from AbstractModelerPropertySection
(and not AbstractPropertySection), because it has already implemented
some standard-things you`ll need.
Cayla Sha schrieb:
> Hello!
> Have fun!
> Julia
>> Hi all.
>> edit part?
>> outdated....
>> Thank you all,
>> Massimiliano
Re: Custom Property Sheet page [message #248570 is a reply to message #248474] Thu, 23 April 2009 06:48 Go to previous message
Hi Julia.
Your help has been very useful and appreciated.
I solved the problem.
Thank you!
Massimiliano
Cayla Sha wrote:
> two additions:
> Cayla Sha schrieb:
>> Hello!
>> Have fun!
>> Julia
>>> Hi all.
>>> edit part?
>>> outdated....
>>> Thank you all,
>>> Massimiliano
Previous Topic:[Announce] GEF 3.5.0 I200904222348 is available
Next Topic:Customize the shape of selection mark
Current Time: Tue Apr 22 16:36:52 EDT 2025
Powered by FUDForum. Page generated in 0.23696 seconds
