Re: Installation problems on Linux/x64 [message #24470 is a reply to message #24429] |
Wed, 31 December 2008 00:37 |
Gustavo de Paula Messages: 118 Registered: July 2009 |
hi elliot,
we never tested mtj on this specific platform, but as far as there is no
reason of why it won't run.
are you able to see MTJ installable units on the "software updates /
installed software" menu? which IU can you see and what is their versions?
other option is to check if MTJ plugins are listed as installed on the
"About / Plugin details" menu
regards,
gep
Elliot Lee wrote:
> I'm running Eclipse 3.4.1 on Fedora 10/x64, and trying to get MTJ 0.9.1
> installed. The update manager installs the plugins just fine, but when I
> restart eclipse and go to "preferences", there is no "Java ME" section in
> the list.
> I have tried installing both the 0.9.1 release, and the nightly build,
> with no success. Are there any suggestions that might help me get this
> working?
> -- Elliot
Re: Installation problems on Linux/x64 [message #24911 is a reply to message #24511] |
Fri, 09 January 2009 01:03 |
Originally posted by: craigjunk.setera.org
Are there any errors in your workspace log that would tell more about
why the plugins don't appear to be correctly loading?
Elliot Lee wrote:
> Hi Gustavo,
> Thanks for your reply. After wiping my ~/.eclipse directory and
> reinstalling the nightly build of MTJ, I checked in 'About ->
> Configuration Details' and the following relevant plugins are listed:
> org.eclipse.mtj.core (0.9.1.200812300802) "MTJ Core Plug-in
> (Incubation)" [Installed]
> org.eclipse.mtj.core.hooks (0.9.0.200812300802) "MTJ Core Hooks Plug-in
> (Incubation)" [Starting]
> org.eclipse.mtj.core.library (0.9.1.200812300802) "MTJ Library Plug-in
> org.eclipse.mtj.core.preverifier (0.9.0.200812300802) "MTJ Preverifier
> Plug-in (Incubation)" [Starting]
> org.eclipse.mtj.doc.user (0.9.0.200812300802) "MTJ User Documentation
> Plug-in (Incubation)" [Resolved]
> org.eclipse.mtj.jmunit (0.9.1.200812300802) "MTJ JMUnit support Plug-in
> org.eclipse.mtj.toolkit.microemu (0.9.1.200812300802) "MTJ Microemulator
> Support Plug-in (Incubation)" [Installed]
> org.eclipse.mtj.toolkit.mpowerplayer (0.9.1.200812300802) "MTJ
> Mpowerplayer Support Plug-in (Incubation)" [Installed]
> org.eclipse.mtj.toolkit.uei (0.9.1.200812300802) "MTJ Base UEI Support
> org.eclipse.mtj.ui (0.9.1.200812300802) "MTJ UI Plug-in (Incubation)"
> [Installed]
> I'm not sure how to proceed from here. I doubt x86_64 is the problem. I
> do wonder why the "Core Hooks" and "Core Preverifier" plugins are listed
> as "Starting" instead of "Installed".
> BTW, the version on a bunch of these is listed as 0.9.0.200812300802 in
> the config details dialog, even though in About -> Features, the "Mobile
> Tools..." features are listed as version 0.9.1.200812300802.
> Take care,
> -- Elliot
Re: Installation problems on Linux/x64 [message #569394 is a reply to message #24429] |
hi elliot,
regards,
gep
Elliot Lee wrote:
> the list.
> working?
> -- Elliot
FUDForum. Page generated in 0.03822 seconds
