Home » Modeling » EMF » Override getText for EClass
Override getText for EClass [message #1407585] Wed, 13 August 2014 01:10 Go to next message
Alain Picard is currently offline Alain PicardFriend
I need to overwrite the behavior of getText() that is in EClassItemProvider. Since this is a provided class, what is the best way to do this?
Alain
Re: Override getText for EClass [message #1407622 is a reply to message #1407585] Wed, 13 August 2014 03:59 Go to previous messageGo to next message
Alain,
You could subclass EcoreItemProviderAdapterFactory to create a subclass
of EClassItemProvider and use that factory in your ComposedAdapterFactory.
> way to do this?
> Thanks
> Alain
Re: Override getText for EClass [message #1407794 is a reply to message #1407622] Wed, 13 August 2014 13:16 Go to previous messageGo to next message
That is what I normally do indeed with our own elements.
But here I'm using a pre-defined control and I don't control the Adapter Factory and registering a factory under "org.eclipse.emf.edit.itemProviderAdapterFactories" either doesn't register more than one factory per uri or returns the first one found.
Alain
Re: Override getText for EClass [message #1407802 is a reply to message #1407794] Wed, 13 August 2014 13:37 Go to previous message
Alain,
To which pre-defined control do you refer? Generally, if you're using
something provided by someone else, and they don't make it configurable,
you have to live with their design decisions...
> Thanks
> Alain
Previous Topic:How to use from an Android application features implemented in EMF project?
Next Topic:[XCORE] GMF: Resource '/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore' does not exist.
Current Time: Fri Feb 21 19:46:09 GMT 2020
Powered by FUDForum. Page generated in 0.01473 seconds
