Home » Eclipse Projects » Eclipse 4 » How to add shortcuts for Dynamic menus.
How to add shortcuts for Dynamic menus. [message #1407216] Tue, 12 August 2014 05:31 Go to next message
Sumit Singh is currently offline Sumit SinghFriend
In my RCP application I'm using dynamic menu.
I want to add shortcuts for that, there is option to set setMnemonics but I want to set shortcut let say ALT+1
    @AboutToShow
    public void aboutToShow(List<MMenuElement> items) {
       MDirectMenuItem dynamicItem = MMenuFactory.INSTANCE.createDirectMenuItem();
       dynamicItem.setLabel("Test Menu");
       dynamicItem.setTooltip("Test Menu tooltip");
       dynamicItem.setContributorURI("platform:/plugin/com.sumit.test");
       dynamicItem.setContributionURI"bundleclass://com.sumit.test/com.sumit.test.TestHandler");
       dynamicItem.setMnemonics("T");
       items.add(dynamicItem);
Shortcut are possible with commands but in this case is there any workaround?.
Sumit
Re: How to add shortcuts for Dynamic menus. [message #1407395 is a reply to message #1407216] Tue, 12 August 2014 13:55 Go to previous message
Brian de Alwis is currently offline Brian de AlwisFriend
No, it's not possible. It goes against the whole approach of commands/keybinding approach: how would the system handle two different direct menu items both specify the same shortcut?
Brian.
Previous Topic:Weird behaviour on standalone Luna application
Next Topic:Fragment plugin not used outside of eclipse
Current Time: Mon Mar 08 17:32:47 GMT 2021
Powered by FUDForum. Page generated in 0.01747 seconds
