Home » Eclipse Projects » Eclipse 4 » Weird behaviour on standalone Luna application(Layout / Styling problems since Kepler -> Luna migration )
Weird behaviour on standalone Luna application [message #1406283] Sat, 09 August 2014 15:45 Go to next message
Ralph Schuster is currently offline Ralph SchusterFriend
I am stucked ith a problem I've been fighting now for 48 hours. My Eclipse/E4 application migrated from Kepler to Luna. In Kepler, there have been no problems and it was working perfectly.
However, there are styling and layout problems with Luna now - but only when I run the application standalone (after a Tycho build). When the application is started from within Eclipse IDE, there are no problems at all.
When run standalone, all tables miss their background and header stylings:
index.php/fa/18837/0/
Some tables suddenly disappear as soon as they require scrollbars:
index.php/fa/18838/0/
Moreover, a customized button (with PaintListener) does not display the color anymore although I could verify that the listener was executed correctly in standalone product:
index.php/fa/18839/0/
You can browse the complete source code at
http://svn.ralph-schuster.eu/websvn/listing.php?repname=RsBudget&path=%2Ftrunk%2F
and some dependency plugins at
http://svn.ralph-schuster.eu/websvn/listing.php?repname=Common+RCP+Plugins&path=%2Ftrunk%2F
Thanks anyone for support
PS: No log messages are issued when the problems occur.
[Updated on: Sat, 09 August 2014 15:46]
Report message to a moderator
Re: Weird behaviour on standalone Luna application [message #1406841 is a reply to message #1406283] Mon, 11 August 2014 08:33 Go to previous messageGo to next message
Short Update: This is only on Linux/Ubuntu. Windows seems to work correctly
Re: Weird behaviour on standalone Luna application [message #1406857 is a reply to message #1406841] Mon, 11 August 2014 09:27 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
You are most likely seen a GTK3 problem. Simply launch with SWT_GTK3=0
in your env and/or configure it through the launcher (use google to find
that info I don't have it at the top of my head)
Tom
Re: Weird behaviour on standalone Luna application [message #1406998 is a reply to message #1406857] Mon, 11 August 2014 16:21 Go to previous message
Hello Tom,
thank you very much. That's the solution. The env var SWT_GTK3=0 fixes this behaviour. (I have Ubuntu 14.04 installed)
Nevertheless, wondering how Eclipse IDE does this internally so it doesn't appear in there.
Previous Topic:How to get access to MPart toolbar elements?
Next Topic:How to add shortcuts for Dynamic menus.
Current Time: Wed Mar 03 00:13:52 GMT 2021
Powered by FUDForum. Page generated in 0.01992 seconds
