Home » Eclipse Projects » GEF » GEF: How to pass parameter values to graphics in the graphics editor
GEF: How to pass parameter values to graphics in the graphics editor [message #247947] Mon, 30 March 2009 10:07
Hi, I have a problem as follow:
GEF's own example "org.eclipse.gef.examples.logic" can be run to create a
graphical editor and draw the logic graphs.
I want to write a java programme on my own to set the input of the logic
graph, and then get the output from it.
For example, I created a new file named "test.logic" and add an
OrGate(OrGate #1). Then I created test1.java under the same project. How
can I refer to the OrGate and set its both terminals valus I defined ?
Thank you in advance!
patiner
Previous Topic:How to zoom in/out SVG(vector image) images like PowerPoint with using GEF
Next Topic:Regarding PropertySheetView
Current Time: Sat Apr 19 12:01:31 EDT 2025
Powered by FUDForum. Page generated in 0.02987 seconds
