Re: Dynamic creation of tool [message #1405943 is a reply to message #1405669] |
Fri, 08 August 2014 15:01 |
Le 08/08/2014 01:24, Arunkumar Ramaswamy a écrit :
> My usecase is that I need an edge creation tool. There are different
> (variable) types of edges which are deduced from the current instance of
> model.
What do you mean by "type of edges" in this context?
The structure of a Sirius VSM is fixed at runtime, so the set of Edge
Mapping available is fixed and can not vary depending on the instance
being edited.
If what varies in your case for each type is styling, you can look at
conditional styles, computed colors, and style customizations, to
compute the edge's style depending on characteristics of the underlying
semantic elements it represent, but in that case you don't need a
dynamic number of edge mappings and corresponding creation tools.
> The are two solutions that i anticipate
> 1. Create variable number of edge creation tool in the tool palaette.
> But i don't how to do with sirius. The number of tools should be dynamic
> based on the model.
This is not possible in Sirius.
> 2. Select the edge creation tool, a selection wizard appears to select
> the type of edge, and then click the source and target element.
It really depend on the meaning of "type of edge" in your case.
Pierre-Charles David - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.04641 seconds
