Home » Modeling » TMF (Xtext) » OSX getting started with xtext(problems getting started with the tutorial)
OSX getting started with xtext [message #1404509] Sat, 02 August 2014 17:24 Go to next message
Lars QuentmeierFriend
Somehow I cannot get the 5 minute tutorial(https://www.eclipse.org/Xtext/documentation.html) to run on my Macbook (OSX 10.9.3)
Is there still something I have to configure before choosing Run As -> Generate Xtext Artifacts?
----------------------JAVA Version:---------------------------------------
java version "1.7.0_06"
Java(TM) SE Runtime Environment (build 1.7.0_06-b24)
Java HotSpot(TM) 64-Bit Server VM (build 23.2-b09, mixed mode)
----------------------Eclipse Console Output:---------------------------------------
176 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
380 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
384 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
400 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
400 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
612 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:95)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:143)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:114)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:66)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:142)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:80)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:93)
... 4 more
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
... 37 more
Caused by: org.eclipse.xtext.resource.ClasspathUriResolutionException: org.eclipse.xtext.resource.FileNotFoundOnClasspathException: Couldn't find resource on classpath. URI was 'classpath:/org/xtext/example/mydsl/MyDsl.xtext'
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.resolve(ClassloaderClasspathUriResolver.java:48)
at org.eclipse.xtext.resource.XtextResourceSet.resolveClasspathURI(XtextResourceSet.java:160)
at org.eclipse.xtext.resource.XtextResourceSet.access$0(XtextResourceSet.java:159)
at org.eclipse.xtext.resource.XtextResourceSet$1.normalize(XtextResourceSet.java:216)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:178)
at org.eclipse.xtext.generator.LanguageConfig.setUri(LanguageConfig.java:205)
... 42 more
Caused by: org.eclipse.xtext.resource.FileNotFoundOnClasspathException: Couldn't find resource on classpath. URI was 'classpath:/org/xtext/example/mydsl/MyDsl.xtext'
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.findResourceOnClasspath(ClassloaderClasspathUriResolver.java:60)
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.resolve(ClassloaderClasspathUriResolver.java:45)
... 47 more
Re: OSX getting started with xtext [message #1404519 is a reply to message #1404509] Sat, 02 August 2014 19:35 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
do you have any errors (red exclamation mark) on the project?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: OSX getting started with xtext [message #1404528 is a reply to message #1404519] Sun, 03 August 2014 08:47 Go to previous messageGo to next message
No,just some warnings.
By the way I had no trouble at all to get things ups an running on my windows machine Sad
Warnings:
Description Resource Path Location Type
The JRE container on the classpath is not a perfect match to the 'J2SE-1.5' execution environment MANIFEST.MF /org.xtext.example.mydsl/META-INF line 16 Plug-in Problem
The JRE container on the classpath is not a perfect match to the 'J2SE-1.5' execution environment MANIFEST.MF /org.xtext.example.mydsl.tests/META-INF line 21 Plug-in Problem
The file "plugin.xml" does not exist in the workspace build.properties /org.xtext.example.mydsl line 6 Plug-in Problem
There is no 'jre.compilation.profile' build entry and the project has Java compliance preferences set build.properties /org.xtext.example.mydsl.tests line 1 Plug-in Problem
There is no 'jre.compilation.profile' build entry and the project has Java compliance preferences set build.properties /org.xtext.example.mydsl.ui line 1 Plug-in Problem
There is no 'jre.compilation.profile' build entry and the project has Java compliance preferences set build.properties /org.xtext.example.mydsl line 1 Plug-in Problem
The JRE container on the classpath is not a perfect match to the 'J2SE-1.5' execution environment MANIFEST.MF /org.xtext.example.mydsl.ui/META-INF line 13 Plug-in Problem
The file "plugin.xml" does not exist in the workspace build.properties /org.xtext.example.mydsl.ui line 6 Plug-in Problem
Re: OSX getting started with xtext [message #1404530 is a reply to message #1404528] Sun, 03 August 2014 10:27 Go to previous messageGo to next message
then i have no idea what could cause this. maybe you have build automatically disabled.
Re: OSX getting started with xtext [message #1404536 is a reply to message #1404530] Sun, 03 August 2014 16:08 Go to previous messageGo to next message
Hm no clue what is the problem (build automatically is enabled). For now I'll work with the windows machine...
[Updated on: Sun, 03 August 2014 16:09]
Report message to a moderator
Re: OSX getting started with xtext [message #1404538 is a reply to message #1404536] Sun, 03 August 2014 18:44 Go to previous message
you could have checked if the xtext file is copied to the bin folder. it usually works fine on macs.
[Updated on: Sun, 03 August 2014 18:44]
Previous Topic:XText Cross References with loops
Next Topic:Problem with import warning in xtext grammar
Current Time: Fri Nov 27 04:34:32 GMT 2020
Powered by FUDForum. Page generated in 0.01631 seconds
