OSX getting started with xtext [message #1404509] |
Sat, 02 August 2014 17:24  |
Lars Quentmeier Messages: 3 Registered: August 2014 |
Somehow I cannot get the 5 minute tutorial(https://www.eclipse.org/Xtext/documentation.html) to run on my Macbook (OSX 10.9.3)
Is there still something I have to configure before choosing Run As -> Generate Xtext Artifacts?
----------------------JAVA Version:---------------------------------------
java version "1.7.0_06"
Java(TM) SE Runtime Environment (build 1.7.0_06-b24)
Java HotSpot(TM) 64-Bit Server VM (build 23.2-b09, mixed mode)
----------------------Eclipse Console Output:---------------------------------------
176 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
380 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
384 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
400 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
400 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
612 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:95)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:143)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:114)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:66)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:142)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:80)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:93)
... 4 more
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
... 37 more
Caused by: org.eclipse.xtext.resource.ClasspathUriResolutionException: org.eclipse.xtext.resource.FileNotFoundOnClasspathException: Couldn't find resource on classpath. URI was 'classpath:/org/xtext/example/mydsl/MyDsl.xtext'
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.resolve(ClassloaderClasspathUriResolver.java:48)
at org.eclipse.xtext.resource.XtextResourceSet.resolveClasspathURI(XtextResourceSet.java:160)
at org.eclipse.xtext.resource.XtextResourceSet.access$0(XtextResourceSet.java:159)
at org.eclipse.xtext.resource.XtextResourceSet$1.normalize(XtextResourceSet.java:216)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:178)
at org.eclipse.xtext.generator.LanguageConfig.setUri(LanguageConfig.java:205)
... 42 more
Caused by: org.eclipse.xtext.resource.FileNotFoundOnClasspathException: Couldn't find resource on classpath. URI was 'classpath:/org/xtext/example/mydsl/MyDsl.xtext'
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.findResourceOnClasspath(ClassloaderClasspathUriResolver.java:60)
at org.eclipse.xtext.resource.ClassloaderClasspathUriResolver.resolve(ClassloaderClasspathUriResolver.java:45)
... 47 more
FUDForum. Page generated in 0.01654 seconds
