ignoring text input component [message #1404477] |
Fri, 01 August 2014 15:42 |
olgierd koslowski Messages: 3 Registered: August 2014 |
I have a problem with testing a swing application with Jubula.
An AUT Agent is starting via javaws a jnlp file of the swing application, which takes a while but the login screen appears. Then I try with the action Component with Text Input/Replace to pass a user, pw. What I see, that the input field is focused (cursor) but no input is done. Then its changing to next field with same result but the last click action to the loginbutton works. I tried it with differnt actions, like copy and paste and other input via keyboard, but thats not working. Logs for aut_agent... swing are all empty.
The error message in the reports I got was: "Timeout received before confirming the posted event". I set System Enviroment Variable TEST_RC_IGNORE_TIMEOUT=true /
GD_IGNORE_TIMEOUT=true (which one is the correct in this version?) but still the same, it now continues the execution and the report is complete green (he schoud not, but anyway, I'll remove the timeout and the test will stop at the first input with an timeout error).
Some additional information:
Jubulas SimpleAdder.jar with rewritten tests is working well (as the other test).
Windows 7, using jre 1.7.0_55, test are started from Jubula IDE Version: 8.0.0 (installer-jubula_win32-win32-x86_64)
Some components are working but this input not, I'm missing detailed information in logs, maybe someone can help.
FUDForum. Page generated in 0.03259 seconds
