Re: OM2M using CoAP [message #1404284 is a reply to message #1404280] |
Wed, 30 July 2014 21:40 |
Mahdi Ben Alaya Messages: 229 Registered: November 2013 |
Hello Han,
We just finished the development of the OM2M CoAP binding plugin.
This extension will enable CoAP communication on the WAN (between NA/NSCL, and NSCL/GSCL) and also on the LAN (between GA/GSCL, and 6LowPan-Constraint-devices/GSCL).
The source code will be available in the next few days.
Mahdi
[Updated on: Wed, 30 July 2014 21:47] Report message to a moderator
Re: OM2M using CoAP [message #1432786 is a reply to message #1405589] |
Sat, 27 September 2014 18:41 |
Hello Han,
I pushed new version of OM2M including the CoAP binding plugin.
You can now configure the CoAP listening port using this parameter: "org.eclipse.om2m.coap.port" available on the config.ini file for NSCL and GSCL.
It is possible to use this the new binding to connect CoAP-enabled Network application or device application. I am writing new tutorial to explain in more details how to use the APoC feature (Application Point of Contact).
I advice you to test this new plugin using the Copper add-on for Firefox (https://addons.mozilla.org/en-US/firefox/addon/copper-270430/)
Here is an example of a CoAP request:
coap://127.0.0.1:5683/om2m/nscl?authorization=admin:admin
I am working now on a new MQTT interworking proxy to monitor and control MQTT-enabled devices. Please tell me if it is interesting for you.
PS: be careful, in the new update, I changed the admin password format like this admin:admin (instead of admin/admin) to make it simple.
Please contact me if you notice any bug.
Waiting for your feedback.
Mahdi
[Updated on: Sat, 27 September 2014 18:44] Report message to a moderator
FUDForum. Page generated in 0.04106 seconds
