Home » Modeling » QVT-OML » Run exported transformation
Run exported transformation [message #1404101] Tue, 29 July 2014 11:35 Go to next message
In short: how to package qvto transformations in a plugin such that they can be executed from eclipse in a run configuration?
I've created a QVTo transformation using eclipse wizard: new Operational QVT transformation. That one works.
Now I exported the project holding the transformation using eclipse export as 'Deployable plugins and fragments'.
After restarting ecipse, I expected to be able to create a new run configuration executing the QVTo transformation as stored in my (exported) plugin. However trying to enter the transformation in the dialog, by using the 'browse' button, does not show the transformation. It shows an entry labeled "Platform" but that one does not contain anything.
Do I need to do something special to have eclipse recognize transformations that are stored in a plugin?
Greetings,
Wilbert.
Re: Run exported transformation [message #1404104 is a reply to message #1404101] Tue, 29 July 2014 11:50 Go to previous messageGo to next message
Have you checked that everything is actually in the exported plugin.
I've not tried deplayable plugins, but certainl;y when building p[lugins
relevant files/folders must appear in build.properties.
Also worth exporting a canned launch config to see if that works.
Otherwise a Bugzilla with a repro.
Ed Willink
On 29/07/2014 16:35, Wilbert Alberts wrote:
> Greetings,
> Wilbert.
Re: Run exported transformation [message #1404186 is a reply to message #1404104] Wed, 30 July 2014 06:01 Go to previous messageGo to next message
Added bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=440737
Greetings,
Wilbert.
Re: Run exported transformation [message #1404310 is a reply to message #1404186] Thu, 31 July 2014 03:35 Go to previous message
You have to register the deployed transformation using an extension point (as also replied in the bug report).
<?eclipse version="3.0"?>
<plugin>
<extension
point="org.eclipse.m2m.qvt.oml.runtime.qvtTransformation">
<transformation
file="transforms/PlatformBug.qvto"
id="transforms.PlatformBug">
</transformation>
</extension>
</plugin>
Previous Topic:How to evaluate OCL expression that is part of the input model
Next Topic:Dynamic set of input models
Current Time: Fri Jun 13 17:04:43 EDT 2025
Powered by FUDForum. Page generated in 0.35825 seconds
