RAP 3.0? [message #1403999] |
Tue, 29 July 2014 05:46 |
Ed Merks Messages: 33137 Registered: July 2009 |
I see there is a RAP 3.0 planned, apparently for December. This implies
API breakage. How can I find out more about how this will affect me,
i.e., how will EMF's RAP integration be impacted?
I assume the Mars release train will include some RAP 3.x version and I
assume that the Luna service releases will include RAP 2.3.x releases or
perhaps a 2.4.x. Are these good assumptions?
Ed
Ed Merks
Re: RAP 3.0? [message #1404012 is a reply to message #1403999] |
Tue, 29 July 2014 07:29 |
Good Morning Ed,
you are correct in your assumption that RAP 3.0 will contain some breaking API changes. When we did the last breaking upgrade to RAP 2.0 we maintained a document with all our changes, but this document is not yet ready for 3.0. The same applies for the planning: I will try to summarize the already known changes in a document and/or in the project plan.
All our scheduled versions can be found here:
https://projects.eclipse.org/projects/rt.rap/documentation
Luna will see updates to our currently released 2.3 stream, i.e. Luna SR1 will include RAP 2.3.1, and Luna SR2 next year will include 2.3.2. Even if we could update theoretically in SR2 to RAP 3.0 we don't have any plans in this direction.
RAP 3.0 is planned for this December, and (similar to RAP 2.0 a few years ago) we are planning to contribute RAP 3.1 to the Mars release next year.
Hope that helps for the moment.
Markus
Twitter: @mknauer23 and @EclipseRAP
Re: RAP 3.0? [message #1404014 is a reply to message #1404009] |
Ivan,
Thanks for the info. Our builds are pointing at RAP's nightly build,
and those have been picking up 3.x, which is why I noticed. (That's even
the case for the emf-maintenance build which is targeted for Luna SR0,
so that's bad.) At least the builds themselves haven't been failing, so
that looks promising.
On 29/07/2014 9:18 AM, Ivan Furnadjiev wrote:
> Hi Ed,
> yes... Luna service releases will include RAP 2.3.x releases. Mars
> release train will include RAP 3.1 version. RAP 3.0 is planned for
> December. About API changes - all deprecated classes (API) will be
> removed (most of them are already removed from master branch, upcoming
> 3.0M1). You could give the latest nightly [1] a try to see how EMF's
> RAP integration is affected. As usual, we will provide a RAP 3.0
> migration guide (similar to 2.0).
> [1] https://www.eclipse.org/rap/downloads/
> Best,
> Ivan
Ed Merks
FUDForum. Page generated in 0.08605 seconds
