Strang error with Nebula grid [message #1403524] |
Thu, 24 July 2014 09:48  |
Marcel Austenfeld Messages: 156 Registered: July 2009 |
i updated the Nebula grid componenta and realized a great speed improvement which is great.
However i got strange errors after a time if i add columns to my grid table.
The following error occurs occasionally:
java.lang.IndexOutOfBoundsException: Index: 14, Size: 13
at java.util.ArrayList.rangeCheckForAdd(ArrayList.java:646)
at java.util.ArrayList.add(ArrayList.java:458)
at org.eclipse.nebula.widgets.grid.GridItemDataVisualizer.addColumnToMap(GridItemDataVisualizer.java:388)
at org.eclipse.nebula.widgets.grid.GridItemDataVisualizer.addColumn(GridItemDataVisualizer.java:369)
at org.eclipse.nebula.widgets.grid.Grid.newColumn(Grid.java:7428)
at org.eclipse.nebula.widgets.grid.GridColumn.init(GridColumn.java:247)
at org.eclipse.nebula.widgets.grid.GridColumn.<init>(GridColumn.java:207)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:519)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:462)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1122)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1006)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:147)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:630)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:574)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:133)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:103)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:378)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:232)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1462)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
!ENTRY org.eclipse.ui 4 0 2014-04-30 14:46:38.964
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.nebula.widgets.grid.internal.DefaultColumnHeaderRenderer.paint(DefaultColumnHeaderRenderer.java:116)
at org.eclipse.nebula.widgets.grid.Grid.paintHeader(Grid.java:5386)
at org.eclipse.nebula.widgets.grid.Grid.onPaint(Grid.java:4900)
at org.eclipse.nebula.widgets.grid.Grid.access$2(Grid.java:4880)
at org.eclipse.nebula.widgets.grid.Grid$4.paintControl(Grid.java:5969)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:230)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1491)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4667)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5020)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
Is this a known bug? The grid library version i currently use was downloaded about 2 months ago (don't know the version number).
[Updated on: Thu, 24 July 2014 09:53] Report message to a moderator
Re: Strang error with Nebula grid [message #1403682 is a reply to message #1403543] |
Fri, 25 July 2014 09:45   |
Hello Mirko,
before i file a bug here an easy example. The eventually bug was hard to reproduce.
Please select the last column (or the column before) and insert a column at the selection. The application will crash.
Select the first or second column and everything will work fine.
Alter the source and remove the text from the grid (remove all gridItem.setText... )all selections will work fine.
So it seems that it has something to do with the text in a grid item.
Source to reproduce:
import org.eclipse.nebula.widgets.grid.Grid;
import org.eclipse.nebula.widgets.grid.GridColumn;
import org.eclipse.nebula.widgets.grid.GridEditor;
import org.eclipse.nebula.widgets.grid.GridItem;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class TestGrid {
private static Grid grid;
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setSize(800, 518);
Composite composite = new Composite(shell, SWT.NONE);
composite.setLayout(null);
Button btnNewButton = new Button(composite, SWT.NONE);
btnNewButton.setBounds(640, 0, 144, 66);
btnNewButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
Point[] sel = grid.getCellSelection();
if (sel.length == 0) {
GridColumn column = new GridColumn(grid, SWT.NONE, grid
.getColumnCount());
column.setWidth(50);
} else {
System.out.println("Columns: "+grid.getColumnCount()+" Selected Column: "+sel[0].x);
GridColumn column = new GridColumn(grid, SWT.NONE, sel[0].x);
btnNewButton.setText("Add Column");
grid = new Grid(composite, SWT.BORDER);
grid.setBounds(0, 0, 622, 456);
grid.setHeaderVisible(true);
// Show row header
grid.setRowHeaderVisible(true);
// Enable cell selection
grid.setRowsResizeable(true);
grid.setCellSelectionEnabled(true);
GridColumn gridColumn = new GridColumn(grid, SWT.NONE);
gridColumn.setText("C1");
gridColumn.setWidth(50);
GridColumn gridColumn_1 = new GridColumn(grid, SWT.NONE);
gridColumn_1.setText("C2");
gridColumn_1.setWidth(50);
GridColumn gridColumn_2 = new GridColumn(grid, SWT.NONE);
gridColumn_2.setText("C3");
gridColumn_2.setWidth(50);
GridColumn gridColumn_3 = new GridColumn(grid, SWT.NONE);
gridColumn_3.setText("C4");
gridColumn_3.setWidth(50);
final GridEditor editor = new GridEditor(grid);
GridItem gridItem = new GridItem(grid, SWT.NONE);
gridItem.setText("With Text");
GridItem gridItem_1 = new GridItem(grid, SWT.NONE);
gridItem_1.setText("With Text");
GridItem gridItem_2 = new GridItem(grid, SWT.NONE);
gridItem_2.setText("With Text");
editor.horizontalAlignment = SWT.LEFT;
editor.grabHorizontal = true;
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
FUDForum. Page generated in 0.02527 seconds
