Re: Wrong bundle is used as server bundle [message #1403563 is a reply to message #1403560] |
Thu, 24 July 2014 12:28 |
Dennis Geesen Messages: 46 Registered: June 2014 |
Member |
Thanks for the answer. The problem is not how it is shown. The problem is, the wizards don't work, because they create some stubs in the jdbc bundle and some other stubs in the server bundle. When I create a form, the formdata is generated into the jdbc-bundle, but without any annotations or methods/fields and this causes a missing service registration. I guess, this is due to the missing entries, because there the jdbc bundle does not use any extension points... Since the created forms and data classes are therefore corrupt, drag'n'drop does not work anymore... So all advantages of the scout sdk is gone and I have to correct all clases by hand - which is really annoying
Tried the "export as binary and import through the target platform" already, but this does not work. Because now I have no server part (either the server nor the jdbc bundle) in the scout view. In this case no com.example.server - just the client and shared component...
Next, I will try to transform the jdbc bundle into a fragment and hope that this will work...
Re: Wrong bundle is used as server bundle [message #1403601 is a reply to message #1403563] |
Thu, 24 July 2014 14:33 |
Jeremie Bresson Messages: 1252 Registered: October 2011 |
Dennis Geesen wrote on Thu, 24 July 2014 14:28Thanks for the answer. The problem is not how it is shown. The problem is, the wizards don't work, because they create some stubs in the jdbc bundle and some other stubs in the server bundle. When I create a form, the formdata is generated into the jdbc-bundle, but without any annotations or methods/fields and this causes a missing service registration. I guess, this is due to the missing entries, because there the jdbc bundle does not use any extension points... Since the created forms and data classes are therefore corrupt, drag'n'drop does not work anymore... So all advantages of the scout sdk is gone and I have to correct all clases by hand - which is really annoying
You can control where the elements are generated in the Step 2 of the "New Form" wizard. Have you tried it?
You speak from missing stuff. Have you checked in the Error Log View if the SDK creates errors or warnings?
If so, we would be interested to improve Scout SDK.
FUDForum. Page generated in 0.02822 seconds
