Guice Injection error [message #1403395] |
Wed, 23 July 2014 12:19  |
anudeep arya Messages: 49 Registered: March 2013 |
Member |
Hello Everyone,
I was trying to create an standalone setup for my RCP application.
When i try to createinjector for in my standalone setup.It gives the below exception.
Everything worked fine when the application was in eclipse indigo.When we ported the rcp to eclipse kepler the rcp application works fine,but there is this problem in running the standalone setup.
Below is the trace::
Exception in thread "main" com.google.inject.CreationException: Guice creation errors:
1) Error injecting constructor, java.lang.NoClassDefFoundError: org/eclipse/e4/ui/model/application/ui/MUIElement
at com.harman.sys.oscar.hmood.validation.HMoodJavaValidator.<init>(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
while locating com.harman.sys.oscar.hmood.validation.HMoodJavaValidator
1 error
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:183)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at com.harman.sys.oscar.hmood.HMoodStandaloneSetupGenerated.createInjector(HMoodStandaloneSetupGenerated.java:28)
at com.harman.sys.oscar.hmood.HMoodStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(HMoodStandaloneSetupGenerated.java:22)
at com.harman.sys.oscar.hmood.HMoodStandaloneSetup.doSetup(HMoodStandaloneSetup.java:10)
at com.harman.sys.oscar.hmood.generator.Main.main(Main.java:116)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/e4/ui/model/application/ui/MUIElement
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:91)
at com.harman.sys.oscar.hmood.tools.ValidateHMood.initialize(ValidateHMood.java:29)
at com.harman.sys.oscar.hmood.tools.ValidateHMood.<init>(ValidateHMood.java:25)
at com.harman.sys.oscar.hmood.tools.ValidateHMood.getInstance(ValidateHMood.java:48)
at com.harman.sys.oscar.hmood.validation.HMoodJavaValidator.<init>(HMoodJavaValidator.java:133)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:85)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.Scopes$1$1.get(Scopes.java:65)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:204)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:198)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:198)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:179)
... 8 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.e4.ui.model.application.ui.MUIElement
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 30 more
Can anyone please help me with the solution for this problem
Anudeep.
[Updated on: Wed, 23 July 2014 12:20] Report message to a moderator
FUDForum. Page generated in 0.02075 seconds
