Somebody ruins my project - glib critical when starting java/swt app [message #1403089] |
Mon, 21 July 2014 10:11 |
Thomas Barth Messages: 6 Registered: July 2014 |
I cant start my Java/SWT Application (SWT libs 4.4) anymore on Ubuntu 14.04 and Debian 7.4. The error message is:
tbarth@ubuntu14:~$ javaws h t t p : / /myaddress.de/myprogram.jnlp
(java:16730): GLib-GObject-WARNING **: cannot register existing type 'GdkDisplayManager'
(java:16730): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
(java:16730): GLib-GObject-CRITICAL **: g_object_new: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
The error messages I get on Ubuntu 12.04 are much larger:
(java:3461): GLib-GObject-WARNING **: specified instance size for type `SwtFixed' is smaller than the parent type's `GtkContainer' instance size
(java:3461): GLib-GObject-CRITICAL **: g_type_add_interface_static: assertion `G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(java:3461): GLib-CRITICAL **: g_once_init_leave: assertion `result != 0' failed
(java:3461): GLib-GObject-WARNING **: specified instance size for type `SwtTextRenderer' is smaller than the parent type's `GtkCellRendererText' instance size
(java:3461): GLib-GObject-WARNING **: specified instance size for type `SwtPixbufRenderer' is smaller than the parent type's `GtkCellRendererPixbuf' instance size
(java:3461): GLib-GObject-WARNING **: specified instance size for type `SwtToggleRenderer' is smaller than the parent type's `GtkCellRendererToggle' instance size
(SWT:3461): GLib-GObject-WARNING **: cannot register existing type `GtkWidget'
(SWT:3461): GLib-GObject-WARNING **: cannot add class private field to invalid type '<invalid>'
(SWT:3461): GLib-GObject-CRITICAL **: g_type_add_interface_static: assertion `G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(SWT:3461): GLib-GObject-WARNING **: cannot register existing type `GtkBuildable'
(SWT:3461): GLib-GObject-CRITICAL **: g_type_interface_add_prerequisite: assertion `G_TYPE_IS_INTERFACE (interface_type)' failed
(SWT:3461): GLib-CRITICAL **: g_once_init_leave: assertion `result != 0' failed
(SWT:3461): Gtk-CRITICAL **: gtk_widget_get_window: assertion `GTK_IS_WIDGET (widget)' failed
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x80d339b4, pid=3461, tid=2190068544
# JRE version: Java(TM) SE Runtime Environment (8.0_11-b12) (build 1.8.0_11-b12)
# Java VM: Java HotSpot(TM) Server VM (25.11-b03 mixed mode linux-x86 )
# Problematic frame:
# C [libgdk-3.so.0+0x259b4] gdk_window_get_type+0x424
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
When I start the application in the browser the window just closes without any messages. But I still can start the application with Eclipse without errors!
Who s responsible for this? SWT People? Oracle with new Java? GTK People? I think this will be the end of my project that was working good in the past years. But now I have to find a provider, who can take over my projekt with another os independent technology. I m astonished that Eclipse Luna still can start without a problem.
[Updated on: Mon, 21 July 2014 11:24] Report message to a moderator
Re: Somebody ruins my project - glib critical when starting java/swt app [message #1403144 is a reply to message #1403089] |
Mon, 21 July 2014 17:04 |
Ok, it s a swt problem. When I sign my application again with swt 4.2.2 libs I can start my JavaWebstart/SWT application without problems on Ubuntu 14.04! The reason why I signed my application with swt 4.4 was, that some of my users reported problems since their last java update on windows 8.1! They just can tell me, that it s not working properly anymore, but I cant test it on win 8.1, because I only have Win 7. But on Win 7 everything is ok. And I had the hope that thier problems get resolved with newer swt libs. I am still waiting for their feedback, but no new complaints so far.
What can I do now to get the devs informed about the problem? Starting a bug report or is this forum also be read by the devs?
[Updated on: Mon, 21 July 2014 17:15] Report message to a moderator
Re: Somebody ruins my project - glib critical when starting java/swt app [message #1403247 is a reply to message #1403144] |
Tue, 22 July 2014 15:30 |
With SWT in 4.4 they moved to using GTK 3 by default. It's possible you're hitting a situation where GTK 2 libraries have already been loaded, which causes a known problem.
You can force SWT to use GTK 2 either by using the launcher option --launcher.GTK_version as documented in the runtime options page (but that will only work if the JNLP invokes the launcher / the executable), or you can also set as an environment variable. It looks like you can also set as a system property too, but you'll have problems if you use the WebKit browser as it only seems to check the environment variable.
Brian.
Re: Somebody ruins my project - glib critical when starting java/swt app [message #1403312 is a reply to message #1403302] |
Tue, 22 July 2014 20:35 |
Thomas Barth wrote on Tue, 22 July 2014 14:34Hello Brian, I don't get the errors when starting eclipse luna and I don't get the errors when starting my application with eclipse although swt 4.4 is imported in workspace.
Sorry, I should have been more explicit. That Eclipse bug describes a situation where the IDE instance was updated from Kepler to Luna. SWT only supported GTK2 in Kepler, whereas Luna supports GTK2 and GTK3. When the updated IDE went to restart, the executable (the eclipse.exe) was already bound to the GTK2 libraries, resulting in an error when SWT tried to bind to GTK3 -- the Eclipse restart is not a true restart.
You might have a similar situation if JNLP is binding to GTK2; does it show a splash screen perhaps?
You wouldn't see this problem with the IDE or when launching your app from the debugger as nothing will be binding to GTK2.
Quote: I only get the errors when using javaws to start my application signed with swt 4.4. The variable SWT_GTK doesnt have an effect. As I can see the option --launcher.GTK_version is for eclipse only.
Note that it's SWT_GTK3.
Brian.
FUDForum. Page generated in 0.04572 seconds
