Re: Scout server not starting anymore [message #1403063 is a reply to message #1402921] |
Mon, 21 July 2014 07:10 |
Lukas Steigerwald Messages: 47 Registered: July 2014 |
Member |
Unfortunately it was maybe too early to say everything is back to working. Just noticed that when trying to start the SWT client the following exception occurs:
org.eclipse.core.runtime.CoreException: Plug-in org.apache.batik.ext.awt was unable to load class org.eclipse.e4.ui.internal.workbench.swt.E4Application.
When checking for the validity of the SWT product file it does not show any errors.
RAP and Swing are starting without exceptions and seem to work as they did before all this trouble.
[Updated on: Mon, 21 July 2014 07:13] Report message to a moderator
Re: Scout server not starting anymore [message #1403073 is a reply to message #1403069] |
Mon, 21 July 2014 08:19 |
Jeremie Bresson Messages: 1252 Registered: October 2011 |
Lukas Steigerwald wrote on Mon, 21 July 2014 10:04If it is the pde-tag in the target file it is version 3.8.
Not exactly. This is the format version of your "*.target" file.
Assuming you have created a new project using the Luna version of Eclipse Scout, the SDK has created a "<your app>.target" project.
How does you tartet file looks like?
If you have:
* A directory location "${scout_rap_target}"
* A software site (*) with a repository location="http://download.eclipse.org/eclipse/updates/3.8"
* A software site (*) with a repository location="http://download.eclipse.org/releases/luna"
=> You are using a 3.8 Eclipse platform (this is what is recommeded).
If you have:
* A directory location "${eclipse_home}"
=> You are using a 4.4 Eclipse platform (this is the default).
Depending on what you selected in the new Scout Project Wizard, you have one or the other.
(*) In the XML, the location tag has a "type" attribute equals to "InstallableUnit" in case of a software site.
[Updated on: Mon, 21 July 2014 08:33] Report message to a moderator
Re: Scout server not starting anymore [message #1693616 is a reply to message #1403175] |
Sun, 26 April 2015 20:11 |
Marco Dörfliger Messages: 46 Registered: January 2015 |
Member |
I'm having a similar problem I just noticed, but I can reproduce it from a freshly downloaded, unmodified scout 4.4 project.
To be specific: my server's production launch configuration reports missing dependencies javax.servlet and javax.servlet.http (when I click on "Validate..." from the server .product configuration).
(edit: for the record, all of the bundles in the screenshot are missing the same two packages)
I take it this doesn't happen for the development .product config because there is a jetty implementation providing those packages. Question is: is it okay to have them missing for the production? Should I just ignore this weirdness, or could it be a symptom of something more sinister?
The thing is, when I export the project and deploy onto a local tomcat server, it works fine (server, rap and swing).
To recreate:
- download and unpack latest eclipse-scout-luna-SR2-win32
- create new workspace with new scout project called "com.test", using New Eclipse Luna target (4.4, current)
- open test-server.product (not the test-dev-server.product). click Validate... to see the dependency warning.
Attachment: error.png
(Size: 19.74KB, Downloaded 884 times)
[Updated on: Sun, 26 April 2015 20:12] Report message to a moderator
FUDForum. Page generated in 0.04044 seconds
