RFC: Can we remove these quirky grammar rules? [message #1402866] |
Fri, 18 July 2014 00:58 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
Boolean Attributes
The current grammar (and future parser) accepts an attribute operation
with the name being a Boolean value. Have you ever seen $true or $false
as parameters in a class, define or type?
i.e.
define foo ($true) {
foo { the_foo: true => false }
Can we get rid of this, it is bad enough that all other keywords can be
used (if, unless, case, class, define, etc. etc.)
Exported with whitespace
The grammar allows the two @@ in an exported resource expression
to be separated by whitepsace. (Both current and future parser).
i.e.
# yes, this works
notify { exported1: message => 'wat' }
@ /* its a little bit odd... */ @
notify { exported2: message => 'wat' }
This creates two exported notify resources.
Can we disallow whitespace between the two @ ?
- henrik
FUDForum. Page generated in 0.03385 seconds
