Home » Eclipse Projects » e(fx)clipse » Error Loading Hooks on Luna
Error Loading Hooks on Luna [message #1402689] Thu, 17 July 2014 10:52 Go to next message
Michael Jastram is currently offline Michael JastramFriend
I *suspect* that I have a Kepler vs. Luna problem. I am building an application that is based on Luna and needs JavaFX access with Java 7.
I configured my application by adding the following VM argument:
-Dosgi.framework.extensions=org.eclipse.fx.osgi
... but I get this error message:
!SESSION 2014-07-17 12:30:13.402 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_40
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi 4 0 2014-07-17 12:30:13.734
!MESSAGE error loading hook: org.eclipse.fx.osgi.fxloader.FXClassLoadingConfigurator
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/osgi/baseadaptor/HookConfigurator
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:792)
	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
The Problem seems to be the HookConfigurator - from Kepler to Luna, the package name changed, from
org.eclipse.osgi.baseadaptor.HookConfigurator
to
org.eclipse.osgi.internal.hookregistry.HookConfigurator
I used the following update site: http://download.eclipse.org/efxclipse/updates-released/0.9.0/site
So this leads to three questions:
  • Am I right that this is a Kepler-Luna incompatibilityy?
  • If so, is there another update site I can use? I need an update site (vs. download), as there is a maven build, relying on a target platform definition consisting exclusively of update sites.
  • I am confused, as 0.9.0 seems to work with Luna quite happily, at least in the IDE. However, I do not want to install the complete IDE features, as I don't want all the JDT dependencies.
Thanks for your help!
- Michael
Re: Error Loading Hooks on Luna [message #1402713 is a reply to message #1402689] Thu, 17 July 2014 11:36 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Yes - if your runtime is based on Luna you need to use the 1.0.0 nightly
builds and their adapter hooks - the reason is that Equinox does not
support the old SPI.
That the tooling 0.9.0 tooling works in Luna is that it does not need to
hooks (unless you open the JavaFX Live Preview which will fail!).
A complete target platform composed solely of runtime components can be
fetched from http://download.eclipse.org/efxclipse/runtime-nightly/site
or http://download.eclipse.org/efxclipse/runtime-nightly/site_assembly.zip
This p2 repo is completely self-contained because it holds equinox, p2,
e(fx)clipse-runtime components and e4.
If you write an RCP application we have another p2 repo which only holds
the adapter hooks and can be retrieved from
http://download.eclipse.org/efxclipse/runtime-shared-nightly/site/ and
http://download.eclipse.org/efxclipse/runtime-shared-nightly/site_assembly.zip
Tom
> java.vendor=Oracle Corporation
> !STACK 0
> at
> to
> - Michael
Re: Error Loading Hooks on Luna [message #1402726 is a reply to message #1402713] Thu, 17 July 2014 11:58 Go to previous messageGo to next message
Hi Tom,
Thanks for the blazingly fast response. I plugged in the new URL, and everything worked right away. I assume that I can just switch to 1.0.0, once it's officially released, right?
Best,
- Michael
Re: Error Loading Hooks on Luna [message #1402736 is a reply to message #1402726] Thu, 17 July 2014 12:14 Go to previous message
Yes you can - we are starting the ramp down for 1.0.0 at the beginning
of next week and plan to release end of month.
Tom
On 17.07.14 13:58, Michael Jastram wrote:
> Hi Tom,
> Best,
> - Michael
Previous Topic:Important upcoming change in toolitem-enablement check
Next Topic:SwingNode - ClassNotFoundException
Current Time: Tue Apr 16 13:42:09 GMT 2024
Powered by FUDForum. Page generated in 0.06826 seconds
