Error in XML page source [message #247193] |
Tue, 10 July 2007 14:08 |
Originally posted by: kale.anuradha.gmail.com
I am new to BIRT reports...
I have written a sample program to create sample2.rptdesign Using BIRT
Design APIs. But I get an error "Error in XML Source page" if I try to open
the output file sample2.rptdesign.
Please help..
// Java program which creates sample2.rptdesign using BIRT Design APIs.
* Copyright (c) 2005 Actuate Corporation.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Actuate Corporation - created
************************************************************ *******************/import java.io.IOException;import org.eclipse.birt.core.framework.Platform;import org.eclipse.birt.report.model.api.CellHandle;import org.eclipse.birt.report.model.api.DesignConfig;import org.eclipse.birt.report.model.api.DesignElementHandle;import org.eclipse.birt.report.model.api.DesignEngine;import org.eclipse.birt.report.model.api.ElementFactory;import org.eclipse.birt.report.model.api.GridHandle;import org.eclipse.birt.report.model.api.IDesignEngine;import org.eclipse.birt.report.model.api.IDesignEngineFactory;impor t org.eclipse.birt.report.model.api.ImageHandle;import org.eclipse.birt.report.model.api.LabelHandle;import org.eclipse.birt.report.model.api.ReportDesignHandle;import org.eclipse.birt.report.model.api.RowHandle;import org.eclipse.birt.report.model.api.SessionHandle;import org.eclipse.birt.report.model.api.activity.SemanticException ;import com.ibm.icu.util.ULocale;/** * Simple BIRT Design Engine API (DEAPI) demo. */public class ReportDesignDemo{ public static void main( String[] args ) { try { buildReport( ); } catch ( IOException e ) { // TODO Auto-generated catch block e.printStackTrace(); } catch ( SemanticException e ) { // TODO Auto-generated catch block e.printStackTrace(); } } // This function shows how to build a very simple BIRT report with a // minimal set of content: a simple grid with an image and a label. static void buildReport( ) throws IOException, SemanticException { // Create a session handle. This is used to manage all open designs. // Your app need create the session only once. //Configure the Engine and start the Platform DesignConfig config = new DesignConfig( ); config.setProperty("BIRT_HOME","C:/birt-runtime-2_2_0/birt-runtime-2_2_0/ReportEngine "); IDesignEngine engine = null; try{ Platform.startup( config ); IDesignEngineFactory factory = (IDesignEngineFactory) Platform .createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_E NGINE_FACTORY ); engine = factory.createDesignEngine( config ); }catch( Exception ex){ ex.printStackTrace(); } SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ; // Create a new report design. ReportDesignHandle design = session.createDesign( ); // The element factory creates instances of the various BIRT elements. ElementFactory factory = design.getElementFactory( ); // Create a simple master page that describes how the report will // appear when printed. // // Note: The report will fail to load in the BIRT designer // unless you create a master page. DesignElementHandle element = factory.newSimpleMasterPage( "PageMaster" ); //$NON-NLS-1$ design.getMasterPages( ).add( element ); // Create a grid and add it to the "body" slot of the report // design. GridHandle grid = factory.newGridItem( null, 2 /* cols */, 1 /* row */ ); design.getBody( ).add( grid ); // Note: Set the table width to 100% to prevent the label // from appearing too narrow in the layout view. grid.setWidth( "100%" ); //$NON-NLS-1$ // Get the first row. RowHandle row = (RowHandle) grid.getRows( ).get( 0 ); // Create an image and add it to the first cell. //ImageHandle image = factory.newImage( null ); CellHandle cell = (CellHandle) row.getCells( ).get( 0 ); //cell.getContent( ).add( image ); //image.setURL("\" http://www.eclipse.org/birt/phoenix/tutorial/basic/multichip -4.jpg\"" ); //image.setURL(" http://www.eclipse.org/birt/phoenix/tutorial/basic/multichip -4.jpg" ); // Create a label and add it to the second cell. LabelHandle label = factory.newLabel( null ); //cell = (CellHandle) row.getCells( ).get( 1 ); cell.getContent( ).add( label ); label.setText( "Hello, world!" ); //$NON-NLS-1$ // Save the design and close it. design.saveAs( "c:/tmp/sample2.rptdesign" ); //$NON-NLS-1$ design.close( ); System.out.println("Finished"); // We're done! }}//Sample2.rptdesign File<?xml version="1.0" encoding="UTF-8"?><report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"id="1"> <styles> <style name="crosstab" id="2"> <property name="borderBottomColor">#CCCCCC</property> <property name="borderBottomStyle">solid</property> <property name="borderBottomWidth">1pt</property> <property name="borderLeftColor">#CCCCCC</property> <property name="borderLeftStyle">solid</property> <property name="borderLeftWidth">1pt</property> <property name="borderRightColor">#CCCCCC</property> <property name="borderRightStyle">solid</property> <property name="borderRightWidth">1pt</property> <property name="borderTopColor">#CCCCCC</property> <property name="borderTopStyle">solid</property> <property name="borderTopWidth">1pt</property> </style> <style name="crosstab-cell" id="3"> <property name="borderBottomColor">#CCCCCC</property> <property name="borderBottomStyle">solid</property> <property name="borderBottomWidth">1pt</property> <property name="borderLeftColor">#CCCCCC</property> <property name="borderLeftStyle">solid</property> <property name="borderLeftWidth">1pt</property> <property name="borderRightColor">#CCCCCC</property> <property name="borderRightStyle">solid</property> <property name="borderRightWidth">1pt</property> <property name="borderTopColor">#CCCCCC</property> <property name="borderTopStyle">solid</property> <property name="borderTopWidth">1pt</property> </style> </styles> <page-setup> <simple-master-page name="Page Master" id="4"/> </page-setup> <body> <grid id="5"> <property name="width">100%</property> <column id="6"/> <column id="7"/> <row id="8"> <cell id="9"> <label id="11"> <text-property name="text">Hello,world!</text-property> </label> </cell> <cell id="10"/> </row> </grid> </body></report>
Re: Error in XML page source [message #247208 is a reply to message #247193] |
Tue, 10 July 2007 14:24 |
I am attaching the two files since the following text is not formatted
well...
Anuradha.
"Anuradha" <kale.anuradha@gmail.com> wrote in message
news:f700b2$in2$1@build.eclipse.org...
> open
> Please help..
> * Contributors:
> DesignConfig( );
> </body></report>
Re: Error in XML page source [message #247298 is a reply to message #247208] |
Wed, 11 July 2007 00:50 |
Wang Qiangsheng Messages: 76 Registered: July 2009 |
Member |
Anuradha wrote:
> well...
> Anuradha.
>> open
>> Please help..
>> * Contributors:
>> DesignConfig( );
>> </body></report>
I can open the file without any errors.
Please confirm if the report design api's version is the same as the
designer's version.
Cheers
Qs
Re: Error in XML page source [message #247343 is a reply to message #247298] |
Wed, 11 July 2007 14:06 |
Hi Qwang,
Thanks for the reply. My BIRT runtime engine version was 2_2_0 and my
BIRT version was 2_1_1.
After using the same version of both my problem is solved now.
Anuradha.
"qwang" <qwang@actuate.com> wrote in message
news:f719g1$ktm$1@build.eclipse.org...
> Anuradha wrote:
>> well...
>> Regards,
>> Anuradha.
>>> Hi,
>>> open
>>> Please help..
>>> * Contributors:
>>> DesignConfig( );
>>> </body></report>
> designer's version.
> Cheers
> Qs
FUDForum. Page generated in 0.03031 seconds
