Re: Xtend editor does not see methods generated from IncQuery patterns until restart [message #1402898 is a reply to message #1402891] |
Fri, 18 July 2014 09:33 |
Zoltan Ujhelyi Messages: 392 Registered: July 2015 |
Hi Christian,
sorry for not being clear; I am reasonably sure I did something unexpected for Xtext in EMF-IncQuery, but I have no idea what it is. Regardless, I have created an example IncQuery project that shows this issue (it requires the latest EMF-IncQuery 0.8 release, available from http://eclipse.org/incquery).
If you uncomment the second pattern from the eiq file, while the xtend editor is already open, the queryGroup.test2 call cannot be created as it does not see the new method from the queryGroup file. However, the query specification generated from the same new pattern is available (see the second commented out line in the Xtend file).
Again, I am mostly interested in some idea what might be going wrong - I really have no idea what might have I been missing.
Thanks for your help,
Zoltán
FUDForum. Page generated in 0.03576 seconds
