Home » Modeling » EMF » [XCORE] How to customize/override attribute getter/setter ?
[XCORE] How to customize/override attribute getter/setter ? [message #1400541] |
Mon, 14 July 2014 10:56 |
xjn Mising name Messages: 20 Registered: May 2010 |
i try to customize/override attribute setters.
The attribute is not dervied, i only woluld like to have some additional code.
Here is my test code, Xtext validation is OK, but
no special body is generated for the setter valueA.
package test
abstract class AbstractBase
/* attribute with overridden setter, XText validation is OK ! */
int valueA
set
checkValue(valueA)
} // !error! no modified setter generated in AbstractBaseImpl class !
/* check method, should be abstract */
op int checkValue(int value)
class A extends AbstractBase
/* special check method for class A */
op int checkValue(int value) {
if (value < -10)
throw new IllegalArgumentException()
value
class B extends AbstractBase
/* special check method for class B */
if (value > 10)
value
Where is my mistake ?
Thx for help
br
xjn
Re: [XCORE] How to customize/override attribute getter/setter ? [message #1400587 is a reply to message #1400541] |
Mon, 14 July 2014 12:26 |
Ed Merks Messages: 33133 Registered: July 2009 |
Xin,
Sorry, that doesn't work. It's only designed to work for derived
features, and even then, only for the getter, and then even many-valued
features are tricky to implement. The setters will be complex to deal
with because you don't want to bypass the notification code.
On 14/07/2014 12:56 PM, xjn Mising name wrote:
> i try to customize/override attribute setters. The attribute is not
> Here is my test code, Xtext validation is OK, but no special body is
> package test
> int valueA
> set
> checkValue(valueA)
> if (value < -10)
> value
> if (value > 10)
> value
> Thx for help
Ed Merks
Re: [XCORE] How to customize/override attribute getter/setter ? [message #1400665 is a reply to message #1400587] |
Mon, 14 July 2014 14:38 |
Ed,
your answer to not support that is not that good and
really a bit unexpected ...
In the XCore syntax this is allowed, for derived and non
derived attributes, both, to override set/get.
Shouldn't at least get/set with bodies for attributes and set
with bodies for derived attributes provide a validation error
in the editor ?
And please, don't tell me again to open a bugzilla for this
As i said before in some message, i'm using modelling for over 20
years and now got the job to migrate all our proprietary modelling
to a de-facto-/pseudo-standard like EMF/XCore.
And many of the expected modelling features are not available or does
not work as expected with EMF/XCore, or are too slow, up to be unusable ...
I'm sorry, i like your work, i like the ideas, but I currently don't
know how to use it for "real life" projects.
The support of loading/saving, notification, validation and UI-/XML-
support seems not to be worth many of the drawbacks, I currently run
into.
There are many things to extend the EMF, i.e. :
- support Class Constants
- support Methods on Enum
- support extensible Singletons
There are many things to extend the XCore, i.e. :
- support "val" and "local val" on class as final static
constants, without getter/setter in interface
- support "var" on class as variables
- support additional argument based constructors in the
Factory
- support Xbase Validation without EMF-Annotions
I'm not focused to Java, as I said, many of my models has to
be migrated from C to Java.
May be I don't understand targeting of your work, please
advise me.
I'm a bit frustrated :)
thx for response
br
xjn
Re: [XCORE] How to customize/override attribute getter/setter ? [message #1400735 is a reply to message #1400665] |
Mon, 14 July 2014 16:42 |
Xjn,
Comments below.
On 14/07/2014 4:38 PM, xjn xjn wrote:
> Ed,
> your answer to not support that is not that good and really a bit
> unexpected ...
> In the XCore syntax this is allowed, for derived and non derived
Yes, the plan is to make it work, eventually.
> Shouldn't at least get/set with bodies for attributes and set with
> bodies for derived attributes provide a validation error in the editor ?
I suppose. I probably shouldn't have put it in the syntax until I'd
implemented it properly.
> And please, don't tell me again to open a bugzilla for this :)
> years and now got the job to migrate all our proprietary modelling to
I see.
> unusable ...
I can't comment on what you're using before...
I know the Canadian Space Agency is using Xcore for a very large
project, so it's definitely used in real life.
> into.
The alternatives, though, are few and far between, aren't they?
It wouldn't kill you to write Java code.
> - support "val" and "local val" on class as final static constants,
Pretty much support every feature possible in Java would be on the list,
but that's a huge effort and no one pays for the results.
> - support "var" on class as variables without getter/setter in interface
> - support additional argument based constructors in the Factory
> I'm not focused to Java, as I said, many of my models has to be
Most people use EMF as a Java generator (and use the structured Ecore
editor or the Ecore Tools graphical editor to create their models).
They write by hand the things that EMF doesn't generate.
> May be I don't understand targeting of your work, please advise me.
> I'm a bit frustrated :);)
If you're hoping to not write any Java code for your more complex types
of problems, i.e., you're not just defining a data model, but you're
want to express a lot of behavior and other concepts that go well beyond
what Ecore captures, that's not a goal you're going to achieve. I don't
know of any solution that will help you achieve that.
> thx for response
Ed Merks
Current Time: Thu Apr 18 05:38:46 GMT 2024
Powered by FUDForum. Page generated in 0.02889 seconds
