Home » Eclipse Projects » SWTBot » How do I launch a certain project in SWTBot Plug-in test?
How do I launch a certain project in SWTBot Plug-in test? [message #1398565] Fri, 11 July 2014 08:50 Go to next message
Pavel Sadovnikov is currently offline Pavel SadovnikovFriend
Not every plugin can be tested without project. For example, I want to test CDT-Plug-in, therefore I need to import a C-project. But there is no such point in Run Configuration and when I'm trying to record importing actions via SWT Plug-in Test recorder SWTBot can't replay them afterwards. Google is silent on this topic. How do I do that?
Re: How do I launch a certain project in SWTBot Plug-in test? [message #1401281 is a reply to message #1398565] Tue, 15 July 2014 11:41 Go to previous message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
You need to import the project programmatically, using SWTBot API you
can call File -> Import -> etc.
as far as I know this is still not handled by the generator, so you need
to write the Java code yourself.
I have some SWTBot tests in my projects, e.g.,
http://xsemantics.sourceforge.net/ , where I import projects (and check
that they compile fine for instance).
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Previous Topic:java.lang.Exception: Could not find plugin
Next Topic:sync after AbstractSWTBot#pressShortcut() ?
Current Time: Wed Sep 29 03:08:18 GMT 2021
Powered by FUDForum. Page generated in 0.01665 seconds
