Home » Modeling » EMF » [XCore] symetric association(the new version of xcore does no longer allow for associations like refers Person[] friends opposite friends)
[XCore] symetric association [message #1396540] Tue, 08 July 2014 12:55 Go to next message
Albert  Zündorf is currently offline Albert ZündorfFriend
I have just donwloaded lua and xcore (anew)
Now the following association:
package org.sdmlib.examples
class Person
String name
creates an error: The opposite may not be its own opposite
This was OK with earlier versions of xcore and I really want it in my model.
Is there some option enabling such assocs or some other trick?
Albert
Re: [XCore] symetric association [message #1396592 is a reply to message #1396540] Tue, 08 July 2014 14:23 Go to previous messageGo to next message
Albert,
You'll see in the newsgroup history that this topic has come up a few
times in the past. Ecore simply doesn't allow this and Xcore maps to
Ecore so it can't allow that either.
> class Person
> String name
> model.
> Albert
Ed Merks
Re: [XCore] symetric association [message #1396660 is a reply to message #1396592] Tue, 08 July 2014 16:08 Go to previous messageGo to next message
Dear Ed,
thanks for your reply.
I am sorry, that I did not find the previous discussions.
'Its forbidden in Ecore' is a perfect reason.
Albeit, it was working before. And although it is forbidden, you could do it in EMF at least recently. Personally, I am ready to do things forbidden by Ecore.
Meanwhile, I will use this as an argument that SDMLib (sdmlib.org) is much better then EMF and Xcore Smile
Greetings
Albert
Re: [XCore] symetric association [message #1396670 is a reply to message #1396660] Tue, 08 July 2014 16:23 Go to previous message
Just as add on:
I have looked up the discussion at https://www.eclipse.org/forums/index.php/mv/msg/457531/1015089/#msg_1015089
I see that there also some technical reasons.
Still, these issues could be solved and I hereby add myself to the list of voters for such a feature.
And, in sdmlib.org this works like a charm Smile
Albert
Previous Topic:[EMF / CDO] Unexpected "Class not found exception"
Next Topic:Operation Id or index reference
Current Time: Fri Aug 14 06:17:10 GMT 2020
Powered by FUDForum. Page generated in 0.02563 seconds
