Re: Anyone had any success with Tigris issue tracker? [message #38591 is a reply to message #38559] |
Fri, 07 December 2007 22:55 |
Eugene Kuleshov Messages: 504 Registered: July 2009 |
Tom Morris wrote:
> It's kind of strange that an open source site like Tigris is using a closed source fork of Bugzilla. If they were just using the standard Bugzilla, we'd be able to use the off the shelf Mylar connector.
> The third party connector that's pointed to on the Mylyn extensions page has an onerous license including field of use restrictions and an anti-compete clause. Does anyone have any alternatives? I did some work a while back on Tigris integration using the Mylar Web connector (back when it was called Mylar), so I'm probably already in violation of the anti-compete clause (or I would be if I downloaded the connector).
> If nothing exists already, I'd be willing to put something together if someone has necessary URLs to plug in to the templates. It's really a waste of effort since it would be better if Tigris just switched to Bugzilla (or something more modern like Trac), but if it's not too much work, I'd be willing to do it to upgrade my current integration.
I am not a lawyer, but I am not aware if CollabNet connector for
IssueZilla has any restrictions on personal use. If you think it is too
prohibitive, perhaps you should report that issue to CollabNet, as they
own both, the Mylyn connector and the server side application.
Also, Mylyn does include web connector that is licensed under EPL,
which doesn't have any prohibitive claims and that connector can be used
to connect to IssueZilla, though it won't provide reach Task Editor and
other nice UI features.
regards,
Eugene
Re: Anyone had any success with Tigris issue tracker? [message #585740 is a reply to message #38559] |
regards,
Eugene
FUDForum. Page generated in 0.05624 seconds
