Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [ECP] Multiple views for the same EObject
Re: [ECP] Multiple views for the same EObject [message #1396367 is a reply to message #1396093] |
Tue, 08 July 2014 07:48 |
Jonas Helming Messages: 699 Registered: July 2009 |
Hi Olivier,
you can either just call the ECPSWTViewRenderer explicitly with a view
model: render(composite, domainObject, viewmodel)
or provide your own View Model provider (it is exchangable)
Best Regards
Jonas
Am 07.07.2014 23:38, schrieb Olivier Labrosse:
> I'm starting to get the hang of using ECP and EMF Forms, and customizing
> everything. One problem I just came across: not being able to open two
> different views on the same EObject, depending on context.
> My understanding is that you would normally decouple views from
> explorers and editors through the use of ViewProviderHelper, which
> handles finding the view provider in the respective extension point.
> For that reason, I would consider it bad practice to fetch a VView
> object directly and creating a ViewModelContext with it.
> I guess my question is, what is the proper way of providing more than
> one view for the same EObject and having them all accessible based on
> context? (as opposed to an arbitrary priority index)
> Your support is always much appreciated.
> Regards,
> Olivier
Re: [ECP] Multiple views for the same EObject [message #1396651 is a reply to message #1396367] |
Tue, 08 July 2014 15:54 |
Olivier Labrosse Messages: 49 Registered: November 2011 |
Member |
Thank you Jonas.
Am I right to think even if I provided my own IViewProvider implementation, there's no way for it to know which view to open, due to the API not supporting context predicates?
If I need to hardcode a call to my IViewProvider implementation through a non-IViewProvider method, I believe I'm better off using a simple helper to fetch a VView based on context, and call on ECPSWTViewRenderer as you suggested.
For the record, one thing I don't like about this (not to say I don't like ECP, I really love it) is that I can't model a simple TreeMasterDetail view where the Detail side is not the "normal" view for the selected EObject. I have to hardcode the former in order to hardcode the call that will render the latter. That is unless I'm missing something?
Thanks again for your help!
Olivier
Jonas Helming wrote on Tue, 08 July 2014 03:48Hi Olivier,
Best Regards
Jonas
> Regards,
> Olivier
Re: [ECP] Multiple views for the same EObject [message #1398278 is a reply to message #1396651] |
Thu, 10 July 2014 22:18 |
Member |
I would like to make the following proposition:
Because this is a must-have feature for us at Benchmark Canada, and we are very much willing to contribute to this project, how about we make the necessary modifications to the MEEditor and relevant components to allow propagating "domain context information" not only to the IViewProviders but also to AbstractMEEditorPages?
Here's a quick rundown of modifications with explanations:
- ECPHandlerHelper gets an overloaded openModelElement(Object, ECPProject, Object) method to accept the domain context object (below referred to as DCO) containing domain-specific information.
- ECPModelElementOpener gets an equivalent overload to the same method, allowing the default EditorModelElementOpener to pass the DCO to the EditorContext.
- ECPEditorContext gets a getter for the DCO, and the default EditorContext gets an overloaded constructor to accept said DCO.
- ViewProviderHelper gets an overloaded getView(EObject, Object) method to accept the DCO and pass it along to the IViewProvider.
- IViewProvider gets overloaded canRender(EObject, Object) and generate(EObject, Object) methods to accept the DCO. Specialized providers would handle the same EObject with a higher priority, but canRender() would return false if the DCO doesn't apply to the provider's purpose.
- MEEditorPage gets updated to pass the DCO to ViewProviderHelper.getView(EObject, Object), at which point the DCO has served its purpose. AbstractMEEditorPage extensions would be able to get the DCO from the ECPEditorContext they are given.
- Of course the idea behind all the overloads is to preserve the existing API and behavior.
Olivier
Re: [ECP] Multiple views for the same EObject [message #1398706 is a reply to message #1396651] |
Fri, 11 July 2014 13:06 |
Am 08.07.2014 17:54, schrieb Olivier Labrosse:
> Thank you Jonas.
> as you suggested.
Yes, that is correct..
> missing something?
So what you would need is to use other view models in the details view
of the tree then if an element is displayed alone in another form?
Best Regards
Jonas
> Olivier
>> Hi Olivier,
>> Best Regards
>> Jonas
>> > Hi,
>> customizing
>> > > Regards,
>> > Olivier
Re: [ECP] Multiple views for the same EObject [message #1398764 is a reply to message #1398706] |
Fri, 11 July 2014 14:51 |
Member |
Exactly.
If I double-click the element in the Model Explorer, I get the full-blown view with two columns, while selecting that same element in another's TreeMasterDetail view would display a one-column view with specific information and hyperlinks.
Jonas Helming wrote on Fri, 11 July 2014 09:06Hi,
> Thank you Jonas.
> as you suggested.
> missing something?
Best Regards
Jonas
> Olivier
>> Hi Olivier,
>> Best Regards
>> Jonas
>> > Hi,
>> customizing
>> > > Regards,
>> > Olivier
Re: [ECP] Multiple views for the same EObject [message #1401152 is a reply to message #1398764] |
Tue, 15 July 2014 07:47 |
I c, Can you open a BR for this, plz?
Am 11.07.2014 16:51, schrieb Olivier Labrosse:
> Exactly.
>> Hi,
>> > Thank you Jonas.
>> due to
>> through
>> ECPSWTViewRenderer
>> > as you suggested.
>> for
>> > missing something?
>> Best Regards
>> Jonas
>> > > Olivier
>> >> Hi Olivier,
>> >> Best Regards
>> >> Jonas
>> >> > Hi,
>> >> customizing
>> open two
>> more than
>> based on
>> >> > > Regards,
>> >> > Olivier
Re: [ECP] Multiple views for the same EObject [message #1402256 is a reply to message #1401152] |
Wed, 16 July 2014 19:17 |
Member |
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=439749
Thank you for looking into this, Jonas. Let us know if our proposition is fair or if it needs some revisions.
Olivier
Jonas Helming wrote on Tue, 15 July 2014 03:47I c, Can you open a BR for this, plz?
> Exactly.
>> Hi,
>> > Thank you Jonas.
>> due to
>> through
>> ECPSWTViewRenderer
>> > as you suggested.
>> for
>> > missing something?
>> Best Regards
>> Jonas
>> > > Olivier
>> >> Hi Olivier,
>> >> Best Regards
>> >> Jonas
>> >> > Hi,
>> >> customizing
>> open two
>> more than
>> based on
>> >> > > Regards,
>> >> > Olivier
Current Time: Thu Apr 25 12:25:06 GMT 2024
Powered by FUDForum. Page generated in 0.04646 seconds
