Re: Annoying repeating message 'Building workspace' on status bar after I version controlled a proje [message #1396733 is a reply to message #1396708] |
Tue, 08 July 2014 17:58 |
Marcos Antonio Messages: 18 Registered: July 2009 |
Junior Member |
Well, I did what you suggested and I see messages like these:
Tue Jul 08 14:54:22 GMT-03:00 2014 - [Worker-10] Auto-Build requested, needsBuil
d: false state: 0 delay: 100
d: false state: 4 delay: 100
Tue Jul 08 14:54:32 GMT-03:00 2014 - [Worker-10] Auto-Build requested, needsBuil
Tue Jul 08 14:54:32 GMT-03:00 2014 - [Worker-3] Auto-Build requested, needsBuild
Tue Jul 08 14:54:42 GMT-03:00 2014 - [Worker-2] Auto-Build requested, needsBuild
Tue Jul 08 14:54:52 GMT-03:00 2014 - [Worker-12] Auto-Build requested, needsBuil
Tue Jul 08 14:55:02 GMT-03:00 2014 - [Worker-7] Auto-Build requested, needsBuild
Tue Jul 08 14:55:03 GMT-03:00 2014 - [Worker-6] Auto-Build requested, needsBuild
Tue Jul 08 14:55:12 GMT-03:00 2014 - [Worker-2] Auto-Build requested, needsBuild
Tue Jul 08 14:55:13 GMT-03:00 2014 - [Worker-1] Auto-Build requested, needsBuild
Tue Jul 08 14:55:23 GMT-03:00 2014 - [Worker-11] Auto-Build requested, needsBuil
Tue Jul 08 14:55:23 GMT-03:00 2014 - [Worker-5] Auto-Build requested, needsBuild
Tue Jul 08 14:55:33 GMT-03:00 2014 - [Worker-3] Auto-Build requested, needsBuild
Tue Jul 08 14:55:33 GMT-03:00 2014 - [Worker-12] Auto-Build requested, needsBuil
Tue Jul 08 14:55:43 GMT-03:00 2014 - [Worker-9] Auto-Build requested, needsBuild
Tue Jul 08 14:55:43 GMT-03:00 2014 - [Worker-6] Auto-Build requested, needsBuild
Tue Jul 08 14:55:53 GMT-03:00 2014 - [Worker-3] Auto-Build requested, needsBuild
Tue Jul 08 14:55:53 GMT-03:00 2014 - [Worker-5] Auto-Build requested, needsBuild
But I don't see any clues or hints where the problem lies. Auto-Builds are requested all the time, but the needsBuild is always false as you can see. I think that this bug is related:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=344090
Although in this bug they're not using EGit. Also I think that there's no solution there.
Any ideas?
[Updated on: Tue, 08 July 2014 18:22] Report message to a moderator
Re: Annoying repeating message 'Building workspace' on status bar after I version controlled a proje [message #1396812 is a reply to message #1396779] |
Tue, 08 July 2014 20:40 |
Junior Member |
Felix Dorner wrote on Tue, 08 July 2014 19:30On 08/07/2014 19:58, Marcos Antonio wrote:
> But I don't see any clues or hints where the problem lies. Do they mean
> something to you?
That means that you don't actually have a problem and I wasted a bit of
time
I haven't had looked ever before but I can now confirm you that I get
the same messages blinking up. The difference seems to be you staring at
the task bar and me staring at the things I need to get done more in the
central area of my screen.
I don't know why auto-build needs a timer, I thought it was based on
resource change events, but tbh, I don't care.
Felix
Maybe you didn't realise how your second paragraph was a bit unprofessional. Anyway, if you cannot be distracted by a status bar flickering almost all the time with a message that doesn't add anything to your work, I admire your concentration. In my point of view this is by no way normal and there's a problem going on with Eclipse regarding this. Contrary to what you said, even if someone is looking at the central area of the screen, he still will see the message blinking up.
For the time being I'll abandon EGit and try the command line git. If someone on the Eclipse team has a solution to this and want to share, I'll be grateful.
This is really not right (maybe the processing in the background, but not the useless and distracting message to the user)
Thank you.
Marcos
[Updated on: Tue, 08 July 2014 20:41] Report message to a moderator
Re: Annoying repeating message 'Building workspace' on status bar after I version controlled a proje [message #1397258 is a reply to message #1397122] |
Wed, 09 July 2014 13:01 |
Junior Member |
Felix Dorner wrote on Wed, 09 July 2014 08:22On 08/07/2014 22:40, I have just tested with a disconnected Java Project and can also confirm
that the Message does not blink up in this case. However, the tracing
console still shows the auto build requests. The only explanation I
might have is that maybe the job manager has more stuff to do when EGit
is active and thus shows slightly different behavior.
Felix
In my opinion, I think that Eclipse (by the way, any IDE) should have the idea and concept of what notifications should be relevant to the user. If some plugin needs to do lots of processing internally to accomplish its responsabilities the end user should not pay the price because of this.
When we save some java file in the workspace and auto build is enable of course we want to be notified in the status bar that there's a build going on, but in this case as the debug message points out:
needsBuild: false state: 4 delay: 100
you can even see that needsBuild is false. I mean, if there was a distinguishing of what messages are relevant to show to the user or not, a message for a thing like this would not be displayed because it doesn't add any relevant information to the end user (and in my case, as I percept the message, annoys as well).
Marcos
FUDForum. Page generated in 0.04099 seconds
