Home » Eclipse Projects » Remote Application Platform (RAP) » error occurred when adding markup to grid!
error occurred when adding markup to grid! [message #1394606] Sat, 05 July 2014 15:34 Go to next message
David Song is currently offline David SongFriend
Hi, I try to add a markup image click event to grid, but error occurred and the code snippets as below,
private String getTag(){
		StringBuffer builder = new StringBuffer();
		builder.append("<a href=\"graphic_info");
		builder.append("\" target=\"_rwt\" style=\"text-decoration:none;\">");
		builder.append(createImageTag("Graphic Info", graphicBtn));
		builder.append("</a> ");
		builder.append("<a href=\"broken_info");
		builder.append(createImageTag("Broked Info", brokedBtn));
		return builder.toString();
grid.addSelectionListener( new SelectionAdapter() {
			  public void widgetSelected( SelectionEvent event ) {
			    if( event.detail == RWT.HYPERLINK ) {
			    	if("graphic_info".equals(event.text)){
			    	}else if("broken_info".equals(event.text)){
and the error code is
2014-07-05 23:19:16.188:WARN:oejs.ServletHandler:ERROR:  /
java.lang.UnsupportedOperationException: Not a number: null
	at org.eclipse.rap.json.JsonValue.asInt(JsonValue.java:304)
	at org.eclipse.nebula.widgets.grid.internal.gridkit.GridOperationHandler.readIndex(GridOperationHandler.java:253)
	at org.eclipse.nebula.widgets.grid.internal.gridkit.GridOperationHandler.handleNotifySelection(GridOperationHandler.java:182)
	at org.eclipse.nebula.widgets.grid.internal.gridkit.GridOperationHandler.handleNotify(GridOperationHandler.java:69)
	at org.eclipse.nebula.widgets.grid.internal.gridkit.GridOperationHandler.handleNotify(GridOperationHandler.java:1)
	at org.eclipse.rap.rwt.internal.protocol.ControlOperationHandler.handleNotify(ControlOperationHandler.java:1)
	at org.eclipse.rap.rwt.internal.protocol.WidgetOperationHandler.handleNotify(WidgetOperationHandler.java:51)
	at org.eclipse.rap.rwt.internal.protocol.ProtocolUtil.handleOperation(ProtocolUtil.java:70)
	at org.eclipse.rap.rwt.internal.lifecycle.AbstractWidgetLCA.readData(AbstractWidgetLCA.java:53)
	at org.eclipse.nebula.widgets.grid.internal.gridkit.GridLCA.readData(GridLCA.java:106)
	at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$3.doVisit(DisplayLCA.java:142)
	at org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidgetTreeVisitor.visit(WidgetTreeVisitor.java:40)
	at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(WidgetTreeVisitor.java:52)
	at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.handleChildren(WidgetTreeVisitor.java:127)
	at org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(WidgetTreeVisitor.java:57)
	at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.visitWidgets(DisplayLCA.java:147)
	at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readData(DisplayLCA.java:66)
	at org.eclipse.rap.rwt.internal.lifecycle.ReadData.execute(ReadData.java:27)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.continueLifeCycle(RWTLifeCycle.java:150)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLifeCycle.java:230)
	at org.eclipse.swt.widgets.Display.sleep(Display.java:1253)
	at org.eclipse.rap.rwt.application.AbstractEntryPoint.createUI(AbstractEntryPoint.java:63)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:172)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:284)
	at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:105)
Re: error occurred when adding markup to grid! [message #1396589 is a reply to message #1394606] Tue, 08 July 2014 14:16 Go to previous messageGo to next message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi.
I can not reproduce the issue with RAP 2.3.0. Which RAP version are you
using? Which exact browser?
Greetings,
Tim
Am 05.07.2014 17:34, schrieb Song David:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Tim Buschtöns
Twitter: @EclipseRAP
Re: error occurred when adding markup to grid! [message #1396895 is a reply to message #1396589] Tue, 08 July 2014 23:50 Go to previous message
Hi Tim,
My RAP version is 2.3.0 and I tested on IE 10, Firefox 30 and Chrome 35, and I met the same error.
private void createGrid(final Composite parent) {
		grid = new Grid(parent, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL);
		grid.setData( RWT.MARKUP_ENABLED, Boolean.TRUE );
		grid.setData(RWT.FIXED_COLUMNS, 2);
		GridDataFactory.fillDefaults().align(SWT.FILL, SWT.BEGINNING).hint(SWT.DEFAULT, 460).grab(true, false).applyTo(grid);
		grid.setHeaderVisible( true );
		grid.setLinesVisible( true );
		createColumn( grid, null, "Workshop", 80, SWT.CENTER );
		createColumn( grid, null, "Machine", 80, SWT.CENTER );
		createColumn( grid, null, "Worker", 100, SWT.CENTER );
		createColumn( grid, null, "Line", 80, SWT.CENTER );
		createColumn( grid, null, "Time", 100, SWT.CENTER );
	private GridColumn createColumn( Grid grid, GridColumnGroup group, String name, int width, int style ){
		GridColumn column;
		if( group == null ) {
			column = new GridColumn( grid, style );
		} else {
			column = new GridColumn( group, style );
		column.setText( name );
		column.setWidth( width );
		return column;
	private void queryReport(){
		grid.removeAll();
		GridColumnGroup group = new GridColumnGroup(grid, SWT.CENTER);
    	group.setText("Output(kg)");
		for(int i=1;i<6;i++){
			createColumn(grid, group, String.valueOf(i) + "Level", 100, SWT.CENTER);
	private void setInput(){
		grid.removeAll();
		GridItem gridItem = new GridItem( grid, SWT.NONE );
		gridItem.setText(getTag());
		for(int i=1; i<10;i++){
			gridItem.setText(i,String.valueOf(i));//workshop name
		builder.append(createImageTag("Broken Count", breakCountBtn));
		builder.append(createImageTag("Line Info", breakLineBtn));
	private String createImageTag(String title, String url) {
		return "<img src='" + url
				+ "' width='16' height='16' style='padding-right:5px;border:none' title='" + title + "'/>";
	private void registerImages() {
		try {
			breakLineBtn = registerImage("resources/twister_break.png");
			breakCountBtn = registerImage("resources/twister_bcount.png");
		} catch (IOException exception) {
			throw new RuntimeException("Failed to register images", exception);
	private static String registerImage(String resourceName) throws IOException {
		ResourceManager resourceManager = RWT.getResourceManager();
		if (!resourceManager.isRegistered(resourceName)) {
			InputStream inputStream = CLASSLOADER.getResourceAsStream(resourceName);
			if (inputStream == null) {
				throw new RuntimeException("Resource not found");
			try {
				resourceManager.register(resourceName, inputStream);
			} finally {
				inputStream.close();
		return resourceManager.getLocation(resourceName);
[Updated on: Wed, 09 July 2014 00:00]
Report message to a moderator
Previous Topic:Behavior of the URLLauncher service on different Browsers
Next Topic:TableViewer in IE9, problem with arrow-down keys
Current Time: Wed Apr 08 10:01:40 GMT 2020
Powered by FUDForum. Page generated in 0.06296 seconds
