Re: Integrated Java/C/C+ IDE [message #1709746 is a reply to message #1394084] |
Wed, 30 September 2015 16:34 |
wen liu Messages: 7 Registered: September 2015 |
Junior Member |
Doug Schaefer wrote on Fri, 04 July 2014 19:16You can have a combined IDE. I use one that combines the Eclipse SDK, including Java, CDT, Android, JavaScript, and a bunch of other things all in one. It's a bit clunky to do but can be done. Just go to the Help -> Install New Software... menu item and bring up the install dialog.
First install one of them, Java or C/C++. Then after launching it, select the "Luna - http://download.eclipse.org/releases/luna" item in the "Work with:" selector. Then find the other IDE components you would like in the list and install it.
It's not a great experience and I plan on spending some time this summer working on a real installer and maybe get some of the bigger chunks into the Eclipse Marketplace which has a much nicer UI and experience. But I'm glad you brought this up because confirms for me that we need a good answer so people like yourself can get the IDE flavors you want without having to install multiple IDEs.
I can't find luna on help->work with, what can I do?
besides, are there any bugs/issues/problems after I install CDT?
I'm afraid CDT and JAVE EE won't coexist well with eath other?
Re: Integrated Java/C/C+ IDE [message #1737403 is a reply to message #1737290] |
Thu, 07 July 2016 19:52 |
Tauno Voipio Messages: 742 Registered: August 2014 |
Pridhvi Myneni wrote on Thu, 07 July 2016 04:18I think this is still a problem. Please correct me if I am wrong. As a workaround- I am downloading the zip files, then renaming the outputted folder, and then creating separate shortcuts (eclipse-c, eclipse-java, eclipse-js).
You can get rid of all of them, but one. Leave for instance the C/C++ version, open it and go to Help -> Install New Software. When the dialog prompts for 'Work with', pick the one matching your current installation. The most recent one begins with the text 'Neon - http:// ... '. Just substitute your version (Mars, Luna, Kepler ...) for 'Neon'.
There are sub-menus containing the tools you need. Java has its own and JavaScript is on the Web tools list.
Tauno Voipio
FUDForum. Page generated in 0.04378 seconds
