Re: Sirius Display changes in Resource [message #1393970 is a reply to message #1393872] |
Fri, 04 July 2014 15:12 |
Hi Dat,
According of what you described, that should work by default. Do you
save your ecore model properly after having edited it ?
Make sure that the Sirius preference "Automatic Refresh" is activated.
If your resource (your ecore model) is correctly loaded within the
Sirius Session (you can unfold your resource in the Model Explorer view)
that should work.
Florian
On 07/04/2014 04:40 PM, Dat Nguyen wrote:
> Hi, i'm looking for a way to display Sirius diagram programmatically
> changes of resources.
> For example, i have a ecore model running in editor and i would like to
> change the model in its resource (xml file), and i want to display this
> change in my diagram.
> i have used F5 in my diagram but it doesn't work. when i refresh the
> root file in package explorer, it works. I have no idea to do it
> programmatically.
> Srry, i'm not good at English so i can not explain more clearly.
> Merci d'avance.
FUDForum. Page generated in 0.03628 seconds
