Problem with the batik bundles [message #1392773] |
Wed, 02 July 2014 20:54 |
KW Messages: 12 Registered: July 2009 |
Junior Member |
when I try to integrate vex via the update site
http://download.eclipse.org/vex/milestones/1.1/, I run into problems
with the batik plugins.
org.apache.batik.css
org.apache.batik.util
org.apache.batik.util.gui
org.eclipse.e4.ui.core needs another version (1.6.0) than vex. When I
only set the 1.7.0 version in the run configuration, I get the target
runtime validation error:
Missing Constraint: Require Bundle:org.apache.batik.css;
bunble-version="[1.6.0,1.7.0)"
When I only set the 1.6.0 in the runtime configuration, I get runtime
valiation the error:
org.eclipse.vex.core
bunble-version="1.7.0"
Missing Constraint: Require Bundle:org.apache.batik.util;
When setting both versions in the target runtime configuration, the
validation of the target runtime succeeds, but at application start, it
leads to this error.
!ENTRY org.eclipse.osgi 2 0 2014-07-01 13:01:10.502
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-07-01 13:01:10.502
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.css.core_0.10.100.v20130515-1857.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.core 2 0 2014-07-01 13:01:10.502
!MESSAGE Missing required bundle org.apache.batik.css_[1.6.0,1.7.0).
!MESSAGE Bundle
initial@reference:file:plugins/org.apache.batik.css_1.7.0.v201011041433.jar
was not resolved.
!SUBENTRY 2 org.apache.batik.css 2 0 2014-07-01 13:01:10.502
!MESSAGE Missing required bundle org.apache.batik.util_[1.7.0,1.8.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-07-01 13:01:10.503
!MESSAGE Bundle
initial@reference:file:plugins/org.apache.batik.util_1.6.0.v201011041432.jar
was not resolved.
!SUBENTRY 2 org.apache.batik.util 2 0 2014-07-01 13:01:10.503
!MESSAGE Missing required bundle org.apache.batik.util.gui_[1.6.0,1.7.0).
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.vex.core_1.1.0.M3_KEPLER_201309251650.jar
was not resolved.
!SUBENTRY 2 org.eclipse.vex.core 2 0 2014-07-01 13:01:10.503
!MESSAGE Missing required bundle org.apache.batik.util_1.7.0.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.ui_3.105.0.v20130522-1122.jar
was not resolved.
!SUBENTRY 2 org.eclipse.ui 2 0 2014-07-01 13:01:10.504
!MESSAGE Missing required capability Require-Capability: osgi.ee;
filter="(|(&(osgi.ee=CDC/Foundation)(version=1.0))(&(osgi.ee=JavaSE)(version=1.3)))".
It seems that neither the 1.6 nor the 1.7 version can be resolved?!
Any idea how to fix this problem?
Best Regards
Kris
Re: Problem with the batik bundles [message #1395695 is a reply to message #1394571] |
Mon, 07 July 2014 09:02 |
Junior Member |
Hi Florian,
yes that was also my theoretical knowledge of OSGI, however I am still
unsure, how it everything needs to be configured in an eclipse rcp /
equinox environment.
I also did have the Orbit p2 repository in target defintion, so this was
not the reason for the bundle resolution problem.
But it works now. I first error-tried with the version synchronization
option on feature.xml, but this didn't help. Then I created a new launch
configuration from scratch and after having added the batik 1.7.0
plugins and the org.w3c.events on the needed plugins tab in the new run
configuration, it was working again! Hm, run-configurations and I will
never become real friends...
Redards
Kristian
Am 05.07.14 16:16, schrieb Florian Thienel:
> Hi Kris,
> in theory, having multiple versions of the same bundle is one of the
> major features of OSGi, so it should work - in theory. Now comes
> practice ;)
> 1) Did you include an Eclipse Orbit P2 repo into your target definition?
> This is where we pull the Batik plug-ins from. (e.g.
> http://download.eclipse.org/tools/orbit/downloads/drops/R20140525021250/)
> 2) Does the last error occur when you try to launch your application in
> the IDE? Maybe you have to enable both versions of Batik in the launch
> configuration.
> Florian
FUDForum. Page generated in 0.07729 seconds
