Can we use two master pages in one birt report? [message #244548] |
Mon, 25 June 2007 08:01 |
Originally posted by: HJiang.StateStreet.com
Hi, all
I want to change some contents of the masterpage during runtime. It seems
that after a made any change to the masterpage, the report would use the
latest masterpage setting. I'm wondering that if I can create two master
pages in the report and use each of them for different pages of the
report. Is that possible?
Re: Can we use two master pages in one birt report? [message #244559 is a reply to message #244548] |
Mon, 25 June 2007 09:52 |
Originally posted by: divya.bedi.saterisystems.com
Hi Alan,
This is possible to have multiple master pages in a report. To use multiple
master pages in a report :--
? Create the master pages. You can create as many master pages as you wish
through the Outline view. Right-click MasterPages and choose Insert to add a
new master page to the report design.
? Specify a page break for each report section that uses a different master
page.
? Assign a master page to each report section.
Suppose there is a report which uses two master pages. The first page is the
Portrait master page & the second page is the Landscape master page. The
Portrait master page is applied to the first page of the report, and the
Landscape master page to the rest of the report, using the following
procedure :--
1.) Select the report section that you want to appear on the title page, and
set its Master Page property to Portrait. Then set the Page Break After
property to Always.
2.) Select the first element that appears on the next page, and set its
master page
to Landscape. The Landscape master page is used for the rest of the pages.
Hope this works !!
Divya Bedi
"Alan JIANG" <HJiang@StateStreet.com> wrote in message
news:a84875a6a0aa943ddefabddb3eaec129$1@www.eclipse.org...
> Hi, all
FUDForum. Page generated in 0.03255 seconds
