Limitations in Properties view [message #1392354] |
Wed, 02 July 2014 07:52 |
Benoit Ries Messages: 86 Registered: May 2013 |
Member |
I've just migrated from Obeo Designer 6.2 to Sirius and I have the two following bugs in the Properties view:
1) auto-completion is not working.
2) when I click on a field, for instance "Domain Class", its current value is replaced by the id value (very strange behavior).
Are these known bugs ? any workaround ?
here is my configuration:
Sirius 1.0.0
Eclipse Luna Release (4.4.0)
mac osx 10.9.3
best regards,
Benoît
[Updated on: Wed, 02 July 2014 07:52] Report message to a moderator
Re: Limitations in Properties view [message #1392550 is a reply to message #1392373] |
Wed, 02 July 2014 13:53 |
Hi Benoit,
You mean you opened an existing odesign file created with an Obeo
Designer, and when you getting the focus on a Domain Class field for
instance, the existing value is replaced by an other ?
Florian
On 07/02/2014 10:31 AM, Benoit Ries wrote:
> Unfortunately, this didn't work in my case :(
> and yes it's for auto-completion of acceleo requests.
> any other idea ?
Re: Limitations in Properties view [message #1392572 is a reply to message #1392560] |
Wed, 02 July 2014 14:28 |
Can you create a new bugzilla with a simple test case from your existing
odesign in OD 6.2 ?
Florian
On 07/02/2014 04:12 PM, Benoit Ries wrote:
> yes correct, this is exactly the second issue of this post.
> regards,
> Benoît
Re: Limitations in Properties view [message #1392616 is a reply to message #1392354] |
Wed, 02 July 2014 15:41 |
Le 02/07/2014 09:52, Benoit Ries a écrit :
No idea if this is the issue you have, but we just fixed a bug related
to this on master: https://bugs.eclipse.org/bugs/show_bug.cgi?id=433821
It's small enough that it will probably be backported to the new Sirius
1.0.x maintenance version, but if this looks like your problem, you can
check on a nightly build at
http://download.eclipse.org/sirius/updates/nightly/latest/luna if it
fixes your case.
This sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=423887,
which is apparently caused by a bug on SWT/OSX,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=383750. I'm not sure if we
can do anything in Sirius to work around the issue.
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.03654 seconds
