Home » Modeling » Ecore Tools » Ecore Tools 2 problems(Ecore Tools 2 problems)
Ecore Tools 2 problems [message #1389496] Fri, 27 June 2014 22:46 Go to next message
joss Pf H is currently offline joss Pf HFriend
hello everybody,
I have some problems about modeling, i hope you can help me :
1)how can i distinguish two clases with the same name but from different packages?
I attached an image, I need to see the words "from .."
2)why has a class into a package the icon "from"?
you can see the red circles into packages store1 and store2
3)if I inheritance from a external class, why appear two relations?
you can see the red circle over the inheritance relation. normally one relation should appear because of if i copied one class is because i need to save some relations
I do not know if i should ask these questions in different topics.
best regards!
index.php/fa/18401/0/
Re: Ecore Tools 2 problems [message #1395786 is a reply to message #1389496] Mon, 07 July 2014 11:53 Go to previous messageGo to next message
Cedric Brun is currently offline Cedric BrunFriend
Thanks for your feedback (and the picture which helps a lot)
Please track a feature request : https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Ecoretools
That's a bug indeed. Please, track it too and I'll fix it in the maintenance stream fairly soon : https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Ecoretools
I'm afraid I don't get your point here, GridStoreBase is two times in your diagram (within the package "store" and on the diagram background) and GridStore extends GridStoreBase, the tool will display this relationship then, for each shape. What would you want exactly, that GridStoreBase could be displayed only once for instance ?
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: Ecore Tools 2 problems [message #1399039 is a reply to message #1395786] Sat, 12 July 2014 00:21 Go to previous message
thanks for responding.
I tracked the bugs in point 1 and 2.
If i inherit of the copy(i used the add button from palette) there is not necessity to show other relation to the original because the original class could be in another ecore file o package i think.
best regards!
Previous Topic:Trouble installing/using Ecore Tools SDK
Next Topic:Ecore Tools 2.0 Outline "link with Editor" button
Current Time: Tue May 18 14:25:43 GMT 2021
Powered by FUDForum. Page generated in 0.08042 seconds
