Home » Eclipse Projects » GEF » Palette is empty when run the program
Palette is empty when run the program [message #243674] |
Mon, 16 June 2008 03:25 |
Originally posted by: basten.li.tsss.com.cn
Below is the source code, when run, the palette part is empty, please give
some help for that, thanks very much.
import gef.tutorial.step.Activator;
import gef.tutorial.step.editparts.PartFactory;
import gef.tutorial.step.model.ContentsModel;
import gef.tutorial.step.model.HelloModel;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.gef.DefaultEditDomain;
import org.eclipse.gef.GraphicalViewer;
import org.eclipse.gef.KeyHandler;
import org.eclipse.gef.KeyStroke;
import org.eclipse.gef.palette.CreationToolEntry;
import org.eclipse.gef.palette.MarqueeToolEntry;
import org.eclipse.gef.palette.PaletteDrawer;
import org.eclipse.gef.palette.PaletteGroup;
import org.eclipse.gef.palette.PaletteRoot;
import org.eclipse.gef.palette.SelectionToolEntry;
import org.eclipse.gef.palette.ToolEntry;
import org.eclipse.gef.requests.SimpleFactory;
import org.eclipse.gef.ui.actions.ActionRegistry;
import org.eclipse.gef.ui.actions.DirectEditAction;
import org.eclipse.gef.ui.actions.GEFActionConstants;
import org.eclipse.gef.ui.parts.GraphicalEditorWithPalette;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.swt.SWT;
import org.eclipse.ui.IWorkbenchPart;
import org.eclipse.ui.plugin.AbstractUIPlugin;
public class DiagramEditor extends GraphicalEditorWithPalette {
/**Editor ID**/
public static final String ID="gef.tutorial.step.ui.DiagramEditor";
GraphicalViewer viewer;
public DiagramEditor(){
setEditDomain(new DefaultEditDomain(this));
protected void initializeGraphicalViewer() {
GraphicalViewer viewer=getGraphicalViewer();
ContentsModel parent=new ContentsModel();
HelloModel child=new HelloModel();
child.setConstraint(new Rectangle(0,0,-1,-1));
parent.addChild(child);
HelloModel child1=new HelloModel();
child1.setConstraint(new Rectangle(30,30,-1,-1));
parent.addChild(child1);
HelloModel child2=new HelloModel();
child2.setConstraint(new Rectangle(10,80,80,50));
parent.addChild(child2);
viewer.setContents(parent);
public void doSave(IProgressMonitor arg0) {
// TODO Auto-generated method stub
protected void configureGraphicalViewer() {
super.configureGraphicalViewer();
viewer.setEditPartFactory(new PartFactory());
KeyHandler keyHandler=new KeyHandler();
keyHandler.put(KeyStroke.getPressed(SWT.DEL, 127,0),
getActionRegistry().getAction(
GEFActionConstants.DELETE));
keyHandler.put(KeyStroke.getPressed(SWT.F2, 0),
GEFActionConstants.DIRECT_EDIT));
viewer.setKeyHandler(keyHandler);
protected PaletteRoot getPaletteRoot() {
PaletteRoot root=new PaletteRoot();
PaletteGroup group=new PaletteGroup("Tools");
ToolEntry toolEntry=new SelectionToolEntry();
group.add(toolEntry);
root.setDefaultEntry(toolEntry);
toolEntry=new MarqueeToolEntry();
PaletteDrawer drawer=new PaletteDrawer("Painting");
ImageDescriptor
descriptor=AbstractUIPlugin.imageDescriptorFromPlugin(Activa tor.PLUGIN_ID,
"icons/online.gif");
CreationToolEntry creationToolEntry=new CreationToolEntry("Paint
HM","Paint HeM model",new
SimpleFactory(HelloModel.class),descriptor,descriptor);
drawer.add(creationToolEntry);
root.add(group);
root.add(drawer);
return root;
protected void createActions() {
super.createActions();
ActionRegistry registry=getActionRegistry();
IAction action=new DirectEditAction((IWorkbenchPart)this);
registry.registerAction(action);
getSelectionActions().add(action.getId());
where online.gif is 16*16 icon, Activator.PLUGIN_ID = "gef.tutorial.step";
Re: Palette is empty when run the program [message #243682 is a reply to message #243674] |
Mon, 16 June 2008 05:15 |
The bug is found that there are some bugs at new version GEF plugin. The
enviroment i used is eclipse 3.3.2 and GEF pugin is 3.4.0. Now, change GEF
from 3.4.0 to 3.2.0, and the bug isn't exist.
"Basten.li" <basten.li@tsss.com.cn> wrote in message
news:g34mf0$23k$1@build.eclipse.org...
> /**Editor ID**/
> @Override
> @Override
> @Override
> @Override
> ImageDescriptor
> root.add(group);
> root.add(drawer);
> return root;
> @Override
Current Time: Sat Apr 20 16:11:05 GMT 2024
Powered by FUDForum. Page generated in 0.02868 seconds
