MarkerUpdater doesn't react on refactoring operation [message #243631] |
Thu, 10 May 2007 15:52 |
Originally posted by: schmidts.iese.fraunhofer.de
Hi everybody.
I got a little problem with the position of my resource markers. I defined a
new IMarker that is subtype of Textmarker and Problemmarker. When one of
these markers is attached to a IFile it is shown properly in the editor an
the problems view. I only set the position attribute CHAR_START and
CHAR_END, LINE_NUMBER is not in use.
When ich change the sourcecode in the editor, every marker is moved around
correctly. But when changing the code programatically, i.e. by a refactoring
like renaming the type, the marker start and end positions stay in there old
place.
I tried to use the ExtensionPoint MarkerUpdater and used the
standard-implementation BasicMarkerUpdater for my marker type, but that
class is only called, when the compilationUnit is saved in the editor. A
refactoring doesn't trigger the updater to move the markers.
Can anyone give me a hint, what I am doing wrong here, please?
Best regards, Seb
Rename-Refactoring behaves strange, new incident of the same problem. [message #243708 is a reply to message #243631] |
Mon, 14 May 2007 13:25 |
The problem from my last post is still unresolved, but I found some new
details about it.
I see the source of the misbehaveour in the Rename-Refactoring:
When there is a marker that underlines a method-name and some characters or
even newlines are inserted above its position in the editor it is moved
correctly. On saving the file, the MarkerUpdater persists the new position.
If anonther method, that is located above the marked one, is renamed using
the refactoring, then the marker is moved correctly and the file is saved
automatically, but the MarkerUpdater is not called to change the position
attributes of the marker at the resource.
If now the classname is changed with the refactoring routine, the marker is
placed at the last position that was persisted by the MarkerUpdater, not
regarding the changed length of the class name, and even not regarding the
changed length of the other method.
For example:
public class MyClass{
void method_one(){}
void method_two(){}
^--marker-^
CHAR_START = 56.
Refactoring[Rename] of "method_one" to "method_1" leads to
void method_1(){}
void method_two(){}
^--marker-^
CHAR_START = 54.
Refactoring[Rename] of "MyClass" to "MyRenamedClass" leads to
public class MyRenamedClass{
void method_1(){}
void method_two(){}
^--marker-^
CHAR_START = 56.
I see the main problem in saving the file at the end of refactoring, but not
calling the MarkerUpdater. I didn't find a bug about this case.
Should I open one? And against which PlugIn?
Thanks, Seb
FUDForum. Page generated in 0.03168 seconds
