Home » Modeling » EMF » [CDO] Issues with uploading CLobs in non 1-byte encoding
[CDO] Issues with uploading CLobs in non 1-byte encoding [message #1389157] Fri, 27 June 2014 12:15 Go to next message
Leonid Ripeynih is currently offline Leonid RipeynihFriend
Hi!
I've discovered a problem in CDO Clob handling:
here is the code, which is located in org.eclipse.emf.cdo.spi.server.StoreAccessor:
writeClob(id, -size, new InputStreamReader(new LimitedInputStream(in, -size)));
Next, in org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeClob(byte[], long, Reader)
stmt.setCharacterStream(3, reader, (int)size);
Code in StoreAccessor implies, that the amount of chars (passed to setCharactedStream) is equal to number of bytes passed to LimitedInputStream.
That leads to commit exceptions, whenever text in non-ascii encoding is submited.
Also, i've noticed that there is no encoding passed to InputStreamReader constructor, which means that encoding is platform-dependant, which can easily lead to more issues in future.
Re: [CDO] Issues with uploading CLobs in non 1-byte encoding [message #1390969 is a reply to message #1389157] Mon, 30 June 2014 08:45 Go to previous message
Esteban Dugueperoux is currently offline Esteban DugueperouxFriend
Hi Leonid,
Could you raise a bugzilla with a Gerrit patch-set containing a JUnit
test to reproduce your issues.
Best Regards.
Le 27/06/2014 14:15, Leonid Ripeynih a écrit :
> Hi!
> -size)));
> Next, in
> long, Reader)
> LimitedInputStream.
> submited. Also, i've noticed that there is no encoding passed to
Previous Topic:[CDO] CDOServerExporter Out of memory exception
Next Topic:Xcore and FeatureMaps
Current Time: Mon Jan 20 04:08:49 GMT 2020
Powered by FUDForum. Page generated in 0.01400 seconds
