Home » Language IDEs » Java Development Tools (JDT) » Eclipse doesn't recognize java 8 default method
Eclipse doesn't recognize java 8 default method [message #1388671] Thu, 26 June 2014 15:56 Go to next message
Hi guys, I desperately need help with this, I installed java 8 and set up the classpath variables and everything for jre8, but somehow I keep getting compile-time error about the "default" keyword on java default methods. I have no idea what is going on, I am an beginner, please help me guys Sad Sad Sad .
It shows the error on the "default" keyword.
index.php/fa/18375/0/
JRE I have installed
index.php/fa/18376/0/
the build path
index.php/fa/18377/0/
  • Attachment: default.png
    (Size: 144.56KB, Downloaded 661 times)
  • Attachment: jre.png
    (Size: 140.30KB, Downloaded 611 times)
  • Attachment: variables.png
    (Size: 148.98KB, Downloaded 635 times)
Re: Eclipse doesn't recognize java 8 default method [message #1389247 is a reply to message #1388671] Fri, 27 June 2014 10:39 Go to previous messageGo to next message
You need to specify jdk compliance level. You do it either globally or at the project level.
Re: Eclipse doesn't recognize java 8 default method [message #1389534 is a reply to message #1389247] Fri, 27 June 2014 20:19 Go to previous messageGo to next message
I downloaded Eclipse Luna which has full support for Java 8, and it works beautifully, Eclipse Kepler just doesn't fully support Java 8 I think. But thank you.
Re: Eclipse doesn't recognize java 8 default method [message #1389543 is a reply to message #1389534] Fri, 27 June 2014 20:40 Go to previous message
Kepler required you to install update that added the Java 8 support.
Previous Topic:UI icon are too small for visually impaired users
Next Topic:How call Eclipse Quick Fix programmatically
Current Time: Thu Mar 20 21:24:28 EDT 2025
Powered by FUDForum. Page generated in 0.04800 seconds
