Home » Newcomers » Newcomers » How to get CSS3 autocomplete working in Luna WTP
How to get CSS3 autocomplete working in Luna WTP [message #1388354] Thu, 26 June 2014 10:12 Go to next message
helga deutz is currently offline helga deutzFriend
Hi, I installed Luna and WTP. The CSS proposals are working with Ctrl+Space but the CSS3 things like background-size are not available. The vendor prefixes are missing as well. How do I activate CSS3 support? Thanks.
Re: How to get CSS3 autocomplete working in Luna WTP [message #1388492 is a reply to message #1388354] Thu, 26 June 2014 14:17 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
The default profile in Luna is still CSS2. Bring up the Properties dialog for your web project and you can change the default CSS profile for that project on the Web Content Settings page. If the CSS file is not in a web project, or if you don't want to use the project default, you can also set it using the file's Properties dialog (also Web Content Settings page).
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: How to get CSS3 autocomplete working in Luna WTP [message #1388501 is a reply to message #1388492] Thu, 26 June 2014 14:30 Go to previous messageGo to next message
Thanks for the quick reply. Most of the files I work on are not in a project so it is quite tedious to set that property for each single file I am working on for just a few minutes. I would prefer to set CSS3 globaly. Im sure there must be a way. Who is working with CSS2 nowadays anyway?
BTW I dont have "Web Content Settings" in the properties dialog. Do I need a plugin or something?
cheers
[Updated on: Thu, 26 June 2014 14:34]
Report message to a moderator
Re: How to get CSS3 autocomplete working in Luna WTP [message #1388507 is a reply to message #1388501] Thu, 26 June 2014 14:39 Go to previous messageGo to next message
Not an extra plug-in, no, but it will only appear for projects that have the Static or Dynamic web project facet installed onto them. It should appear for a CSS file regardless.
Nitin Dahyabhai
Re: How to get CSS3 autocomplete working in Luna WTP [message #1389104 is a reply to message #1388507] Fri, 27 June 2014 10:42 Go to previous messageGo to next message
got it working! thanks!
to bad there is no general setting, so I have to do that for every single css file I am edditing - very inefficient workflow
Re: How to get CSS3 autocomplete working in Luna WTP [message #1389319 is a reply to message #1389104] Fri, 27 June 2014 16:30 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Eclipse is project-based; working on individual files isn't it's focus. Thus it's efficiencies are geared towards working in projects.
Re: How to get CSS3 autocomplete working in Luna WTP [message #1828077 is a reply to message #1389319] Sun, 31 May 2020 23:44 Go to previous messageGo to next message
I updated to 2020-03 but still the autocomplete for css "transition" for example still does not work. At least "background-size" is available. I also have WWD installed. How do I get the full css autocomplete working?
Re: How to get CSS3 autocomplete working in Luna WTP [message #1828093 is a reply to message #1828077] Mon, 01 June 2020 12:51 Go to previous message
You can try opening the file with the Generic Editor, but I'm not sure how accurate that content assist is personally.
Nitin Dahyabhai
Previous Topic:Click build project/bulid All, it invoke my tools to compile,how to set?
Next Topic:The Eclipse executable launcher was unable to locate its companion shared library
Current Time: Tue Jan 19 13:24:01 GMT 2021
Powered by FUDForum. Page generated in 0.03371 seconds
