Generating tables from entities [message #1388112] |
Thu, 26 June 2014 02:33 |
Tuan Nguyen Messages: 1 Registered: June 2014 |
Junior Member |
I'm using Eclipse Kepler Release 2 and JPA platform Eclipse 2.5.x to generate tables from entities. I ran into this error:Internal Exception: java.lang.NoClassDefFoundError: org/eclipse/persistence/jpa/jpql/parser/ExpressionVisitor.
What jar file m I missing? I had downloaded the whole Jboss tools into my Eclipse. So not sure where I can get the missing jar file for ExpressionVisitor?
Here's the whole error:
Exception in thread "main" Local Exception Stack:
Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.5.1.v20130918-f2b9fc5): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: org.eclipse.persistence.dynamic.DynamicClassLoader@708f5957
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.1.v20130918-f2b9fc5): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [OBIM Domain] failed.
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionSearchingForPersistenceResources(PersistenceUnitLoadingException.java:127)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:107)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:177)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:55)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.buildEntityManagerFactory(Main.java:94)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.execute(Main.java:80)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.main(Main.java:68)
Caused by: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.1.v20130918-f2b9fc5): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.createPredeployFailedPersistenceException(EntityManagerSetupImpl.java:1954)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1945)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:98)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:96)
... 5 more
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.1.v20130918-f2b9fc5): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:230)
... 9 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/persistence/jpa/jpql/parser/ExpressionVisitor
at org.eclipse.persistence.internal.jpa.metadata.queries.NamedQueryMetadata.addJPAQuery(NamedQueryMetadata.java:105)
at org.eclipse.persistence.internal.jpa.metadata.queries.NamedQueryMetadata.process(NamedQueryMetadata.java:192)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processQueries(MetadataProject.java:1630)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.addNamedQueries(MetadataProcessor.java:148)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1898)
... 7 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.persistence.jpa.jpql.parser.ExpressionVisitor
at java.net.URLClassLoader$1.run(URLClassLoader.java:372)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.net.URLClassLoader.findClass(URLClassLoader.java:360)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 12 more
Appreciate any guidance!
Tuan
FUDForum. Page generated in 0.01602 seconds
