Home » Eclipse Projects » XWT » XWT Table DataBinding(Table Databinding)
XWT Table DataBinding [message #1387592] Wed, 25 June 2014 09:48 Go to next message
Sascha Hanke is currently offline Sascha HankeFriend
Hello there,
I have a problem with XWT databinding. I got my XWT table and a list as an input. I got my columns displayed but it wont show me content. The Eclipse console says:
!ENTRY org.eclipse.core.databinding 2 0 2014-06-25 11:39:22.228
!MESSAGE elementType cannot be null
What can I do to fix this?
My classes :
<Composite xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt" x:Class="de.datec.kassenbuch.ui.xwt.DetailPartXwt" xmlns:p1="clr-namespace:org.eclipse.jface.viewers"
xmlns:p2="clr-namespace:de.datec.kassenbuch.ui.table">
<Composite.layout>
<FillLayout/>
</Composite.layout>
<TableViewer x:Style="BORDER | FULL_SELECTION" input="{Binding path=buchungen}">
<TableViewer.table headerVisible="true" linesVisible="true"/>
<TableViewer.columns headerVisible="true">
<TableViewerColumn width="50" text="ID" bindingPath="id">
<TableViewerColumn.labelProvider>
<p2:IdColumnLabelProvider/>
</TableViewerColumn.labelProvider>
</TableViewerColumn>
<TableViewerColumn width="440" text="Datum" bindingPath="datum">
<p2:DateColumnLabelProvider/>
<TableViewerColumn width="440" text="Betrag" bindingPath="betrag">
<p2:AmountColumnLabelProvider/>
<TableViewerColumn width="400" text="Einnahme / Ausgabe" bindingPath="ausgabe">
<p2:TakeGiveColumnLabelProvider/>
</TableViewer.columns>
</TableViewer>
</Composite>
public DetailPartXwt(Composite parent, int style, Object object) {
super(parent, style);
setLayout(new FillLayout());
// load XWT
String name = DetailPartXwt.class.getSimpleName()
+ IConstants.XWT_EXTENSION_SUFFIX;
try {
URL url = DetailPartXwt.class.getResource(name);
Map<String, Object> options = new HashMap<String, Object>();
TableModel model = new TableModel();
options.put(IXWTLoader.DATACONTEXT_PROPERTY, model);
options.put(IXWTLoader.CLASS_PROPERTY, this);
options.put(IXWTLoader.CONTAINER_PROPERTY, this);
XWT.setLoadingContext(new DefaultLoadingContext(this.getClass()
.getClassLoader()));
XWT.loadWithOptions(url, options);
} catch (Throwable e) {
throw new Error("Unable to load " + name, e);
public class TableModel {
@Inject IDataService dataService;
List<KassenBuchungReduced> buchungen = new ArrayList<KassenBuchungReduced>(); {
KassenBuchungReduced test = new KassenBuchungReduced(1, new Date(120,2,2), 350, false);
public List<KassenBuchungReduced> getBuchungen() {
return buchungen;
public void setBuchungen(List<KassenBuchungReduced> buchungen) {
this.buchungen = buchungen;
Re: XWT Table DataBinding [message #1387888 is a reply to message #1387592] Wed, 25 June 2014 18:43 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
Could you please provide the full stack trace?
Re: XWT Table DataBinding [message #1388226 is a reply to message #1387888] Thu, 26 June 2014 06:25 Go to previous messageGo to next message
Here:
!SESSION 2014-06-26 08:24:55.014 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_55
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product de.datec.kassenbuch.ui.product -clearPersistedState
Command-line arguments: -product de.datec.kassenbuch.ui.product -data C:\Users\sascha.DATEC-SCHMIDT\workspace\EclipseXWT/../runtime-de.datec.kassenbuch.ui.product -dev file:C:/Users/sascha.DATEC-SCHMIDT/workspace/EclipseXWT/.metadata/.plugins/org.eclipse.pde.core/de.datec.kassenbuch.ui.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -clearPersistedState
!ENTRY org.eclipse.core.databinding 2 0 2014-06-26 08:25:04.089
Re: XWT Table DataBinding [message #1388617 is a reply to message #1388226] Thu, 26 June 2014 18:15 Go to previous messageGo to next message
Unfortunately, that is just the internal exception message thrown by the databinding framework.
Instead of this (or additionally):
Do the following and provide the output of it (that is the stack trace):
e.printStackTrace()
Sascha Hanke wrote on Thu, 26 June 2014 08:25
Here:
Re: XWT Table DataBinding [message #1389102 is a reply to message #1388617] Fri, 27 June 2014 10:42 Go to previous messageGo to next message
The problem is that there is no difference.
I don't get any output from
e.printStackTrace()
Edit: I just get the same message I posted before.
[Updated on: Fri, 27 June 2014 10:43]
Report message to a moderator
Re: XWT Table DataBinding [message #1389301 is a reply to message #1389102] Fri, 27 June 2014 15:59 Go to previous messageGo to next message
Maybe, you could extract a standalone sample that reproduces the error message?
And did you check your POJO KassenBuchungReduced? Mabye, it returns null in one of its getters?
Sascha Hanke wrote on Fri, 27 June 2014 12:42
e.printStackTrace()
Re: XWT Table DataBinding [message #1392395 is a reply to message #1389301] Wed, 02 July 2014 09:08 Go to previous messageGo to next message
Hey there,
it was all my fault. I don't know how but I got the wrong Databinding Plugin(wrong Version). I deleted it from my plugin.xml and everything was fine.
Oh yes and my TableModel class had a typo.. shame on me...
Much love for XWT!
Greeting Sascha
Re: XWT Table DataBinding [message #1393292 is a reply to message #1392395] Thu, 03 July 2014 15:06 Go to previous messageGo to next message
now I got a new problem. I've read http://erdalkaracade.blogspot.de/2013/07/eclipse-e4-emf-and-xwt-in-action.htmland I want to export the selection from my table I made with xwt and use it in another part, just like you did.
When I use
<Composite.Resources>
		<Var x:Name="booking" varName="selectedBuchung"/>
	</Composite.Resources>
I get the following error :
!ENTRY org.eclipse.e4.ui.workbench 4 0 2014-07-03 17:02:02.612
!MESSAGE Unable to create class 'de.datec.kassenbuch.ui.view.MoreDetailView' from bundle '126'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.Error: Unable to load MoreDetailPartXwt.xwt
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1147)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:65)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:101)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:62)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:581)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1038)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:162)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.Error: Unable to load MoreDetailPartXwt.xwt
at de.datec.kassenbuch.ui.xwt.MoreDetailPartXwt.<init>(MoreDetailPartXwt.java:45)
at de.datec.kassenbuch.ui.view.MoreDetailView.postConstruct(MoreDetailView.java:50)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 82 more
Caused by: org.eclipse.xwt.XWTException: Type Var is not found.
at org.eclipse.xwt.XWTLoader.getMetaclass(XWTLoader.java:1151)
at org.eclipse.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:434)
at org.eclipse.xwt.javabean.ResourceLoader.applyStyles(ResourceLoader.java:872)
at org.eclipse.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:654)
at org.eclipse.xwt.javabean.ResourceLoader.createUIElement(ResourceLoader.java:366)
at org.eclipse.xwt.internal.core.Core.createCLRElement(Core.java:625)
at org.eclipse.xwt.internal.core.Core.load(Core.java:754)
at org.eclipse.xwt.internal.core.Core.load(Core.java:655)
at org.eclipse.xwt.XWTLoader.loadWithOptions(XWTLoader.java:1072)
at org.eclipse.xwt.XWT.loadWithOptions(XWT.java:623)
at de.datec.kassenbuch.ui.xwt.MoreDetailPartXwt.<init>(MoreDetailPartXwt.java:39)
... 88 more
Has the name changed? Or the whole way to do this?
When I do the e4 Inject/Optional/Named("selectedBuchung") thing, the object i get is null.
@Inject @Optional @Named("selectedBuchung")
	private Object modelElement;
Greeting Sascha
[Updated on: Thu, 03 July 2014 15:06]
Re: XWT Table DataBinding [message #1395275 is a reply to message #1393292] Sun, 06 July 2014 17:30 Go to previous messageGo to next message
Hi Sascha,
The E4 integration using the Var/Export mechanism was a proposal.
Up to now, no feedback from the community, so it did not make into the final release.
You can check out the sources into your workspace and build it yourself, for now:
git: http://git.eclipse.org/c/xwt/org.eclipse.xwt.git/tree/org.eclipse.xwt.e4
If you want this feature to be integrated into XWT itself, please file a new enhancement request.
And please do not hijack existing forum posts for different issues Smile
Sascha Hanke wrote on Thu, 03 July 2014 17:06
When I use
!STACK 0
... 82 more
... 88 more
Greeting Sascha
Re: XWT Table DataBinding [message #1396505 is a reply to message #1395275] Tue, 08 July 2014 11:46 Go to previous message
Hi Erdal,
thanks again for your help!
I'm learning Java/Eclipse since 3 months and I think XWT would make UI development so much faster. The problem is I don't know how to implement this feature myself but I got a different solution. Enhancement request this evening.
Greetings Sascha
Previous Topic:Download and Install XWT
Next Topic:XWT cannot be installed with 3.8.2
Current Time: Sat Oct 16 13:20:51 GMT 2021
Powered by FUDForum. Page generated in 0.02054 seconds
