Re: Index out of bounds when trying to create new setup model [message #1387129 is a reply to message #1387123] |
Tue, 24 June 2014 10:14 |
Hi Felix,
This problem is reported in:
435722: SetupModelWizards dialog is empty due to an IndeOutOfBoundsException
https://bugs.eclipse.org/bugs/show_bug.cgi?id=435722
This bugzilla also contains why that currently happens and how you can easily work around it. Note that Ed already
started to fix the model wizard and even add a model template for Eclipse.org projects.
Cheers
/Eike
http://www.esc-net.de
Am 24.06.2014 11:59, schrieb Felix Dorner:
> To get there I:
> - Downloaded the Oomph installer (win64)
> - Picked EPP Modelling/Luna
> - Picked Oomph/master
> - Oomph IDE installed correctly (I end up with a Luna IDE and a workspace containing the Oomph plugins)
> - Within that IDE I do File->New Setup model.
> Is that a correct way to start authoring a new setup model? So here's the stacktrace.
> Cheers,
> Felix
> java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
> at java.util.ArrayList.rangeCheck(Unknown Source)
> at java.util.ArrayList.get(Unknown Source)
> at
> org.eclipse.oomph.setup.presentation.SetupModelWizard$TemplateUsagePage.createControl(SetupModelWizard.java:1049)
> at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
> at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
> at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1182)
> at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1241)
> at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1238)
> at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1227)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
Cheers
/Eike
FUDForum. Page generated in 0.03356 seconds
