Home » Modeling » TMF (Xtext) » "Select" option as default in list parameter("Select" option as default in list parameter)
"Select" option as default in list parameter [message #1386913] Mon, 23 June 2014 05:32 Go to next message
Ganesh Hegde is currently offline Ganesh HegdeFriend
hey guys..
i hav tried to putting deafult value as "--Select--" for both parameters in the report, but as i select the first parameter the second parameter gets loaded and automatically default value will b changed to "All". I want to keep the default value as "--Select --" only. Can u Please assist me Sad . ..thank you in advance
Re: "Select" option as default in list parameter [message #1386959 is a reply to message #1386913] Mon, 23 June 2014 09:03 Go to previous message
Christian Dietrich is currently online Christian DietrichFriend
i dont see how this is Xtext related. please provide more context
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:Dependency Between Xtext project and Java project
Next Topic:Subclassing code generators (example: Swing UI)
Current Time: Thu Oct 29 05:54:40 GMT 2020
Powered by FUDForum. Page generated in 0.02056 seconds
