eclipselink stackoverflow exceptions - repeating same query thousand of time [message #1386632] |
Wed, 18 June 2014 21:13 |
Ahmad Bahaaeldin Messages: 1 Registered: June 2014 Location: Egypt |
We have project that is already deployed on oracle application server 10.2 on many sites, project uses jsf and eclipse link 2.2.0.
however we have problem in a recent installation that eclipse link keeps executing queries with same bind information thousand of times, till application crash and gives stack overflow error.
We use following code to generate object descriptor:
public ClassDescriptor buildTLEntityPCDAODescriptor() {
RelationalDescriptor descriptor = new RelationalDescriptor();
descriptor.setJavaClass(com.its.tabs.tpc.layers.dal.entity.toplink.TLEntityPCDAO.class);
descriptor.addTableName("TPC_ENTITIES");
descriptor.addPrimaryKeyFieldName("TPC_ENTITIES.ENTITY_ID");
// Inheritance Properties.
// Descriptor Properties.
descriptor.useSoftCacheWeakIdentityMap();
descriptor.setIdentityMapSize(100);
descriptor.useRemoteSoftCacheWeakIdentityMap();
descriptor.setRemoteIdentityMapSize(100);
descriptor.setSequenceNumberFieldName("TPC_ENTITIES.ENTITY_ID");
descriptor.setSequenceNumberName("SEQ_ENTITIES");
descriptor.setAlias("TLEntityPCDAO");
// Cache Invalidation Policy
TimeToLiveCacheInvalidationPolicy policy = new TimeToLiveCacheInvalidationPolicy(1);
policy.setShouldUpdateReadTimeOnUpdate(false);
descriptor.setCacheInvalidationPolicy(policy);
// Query Manager.
descriptor.getQueryManager().checkCacheForDoesExist();
DirectToFieldMapping descriptionMapping = new DirectToFieldMapping();
descriptionMapping.setAttributeName("description");
descriptionMapping.setFieldName("TPC_ENTITIES.DESCRIPTION");
descriptor.addMapping(descriptionMapping);
DirectToFieldMapping serviceProviderCodeMapping = new DirectToFieldMapping();
serviceProviderCodeMapping.setAttributeName("serviceProviderCode");
serviceProviderCodeMapping.setFieldName("TPC_ENTITIES.SERVICE_PROVIDER_CODE");
descriptor.addMapping(serviceProviderCodeMapping);
DirectToFieldMapping entity_idMapping = new DirectToFieldMapping();
entity_idMapping.setAttributeName("entity_id");
entity_idMapping.setNullValue(new Long(0));
entity_idMapping.setFieldName("TPC_ENTITIES.ENTITY_ID");
descriptor.addMapping(entity_idMapping);
DirectToFieldMapping idMapping = new DirectToFieldMapping();
idMapping.setAttributeName("id");
idMapping.readOnly();
descriptor.addMapping(idMapping);
DirectToFieldMapping levelIdMapping = new DirectToFieldMapping();
levelIdMapping.setAttributeName("levelId");
levelIdMapping.setNullValue(new Long(0)); //changed from -1 to 0
levelIdMapping.setFieldName("TPC_ENTITIES.LEVEL_ID");
descriptor.addMapping(levelIdMapping);
DirectToFieldMapping lookupIdMapping = new DirectToFieldMapping();
lookupIdMapping.setAttributeName("lookupId");
lookupIdMapping.setNullValue(new Long(0)); //changed from -1 to 0
lookupIdMapping.setFieldName("TPC_ENTITIES.LOOKUP_ID");
descriptor.addMapping(lookupIdMapping);
DirectToFieldMapping levelDepthMapping = new DirectToFieldMapping();
levelDepthMapping.setAttributeName("levelDepth");
levelDepthMapping.setFieldName("TPC_ENTITIES.LEVEL_DEPTH");
descriptor.addMapping(levelDepthMapping);
DirectToFieldMapping entity_sequenceMapping = new DirectToFieldMapping();
entity_sequenceMapping.setAttributeName("entity_sequence");
entity_sequenceMapping.setNullValue(new Long(0));
entity_sequenceMapping.setFieldName("TPC_ENTITIES.ENTITY_SEQUENCE");
descriptor.addMapping(entity_sequenceMapping);
DirectToFieldMapping entity_typeMapping = new DirectToFieldMapping();
entity_typeMapping.setAttributeName("entity_type");
entity_typeMapping.setFieldName("TPC_ENTITIES.ENTITY_TYPE");
descriptor.addMapping(entity_typeMapping);
DirectToFieldMapping nameMapping = new DirectToFieldMapping();
nameMapping.setAttributeName("name");
nameMapping.setFieldName("TPC_ENTITIES.NAME");
descriptor.addMapping(nameMapping);
DirectToFieldMapping parent_entity_idMapping = new DirectToFieldMapping();
parent_entity_idMapping.setAttributeName("parent_entity_id");
parent_entity_idMapping.setNullValue(new Long(0)); //changed from -1 to 0
parent_entity_idMapping.setFieldName("TPC_ENTITIES.PARENT_ENTITY_ID");
descriptor.addMapping(parent_entity_idMapping);
AggregateObjectMapping auditFieldsMapping = new AggregateObjectMapping();
auditFieldsMapping.setAttributeName("auditFields");
auditFieldsMapping.setReferenceClass(com.its.tabs.architecture.dal.persistency.AuditFields.class);
auditFieldsMapping.setIsNullAllowed(false);
auditFieldsMapping.addFieldNameTranslation("TPC_ENTITIES.CREATED_BY", "createdBy->DIRECT");
auditFieldsMapping.addFieldNameTranslation("TPC_ENTITIES.MODIFIED_BY", "modifiedBy->DIRECT");
auditFieldsMapping.addFieldNameTranslation("TPC_ENTITIES.CREATED_DATE", "createdDate->DIRECT");
auditFieldsMapping.addFieldNameTranslation("TPC_ENTITIES.MODIFIED_DATE", "modifiedDate->DIRECT");
descriptor.addMapping(auditFieldsMapping);
OneToManyMapping entitesMapping = new OneToManyMapping();
entitesMapping.setAttributeName("entites");
entitesMapping.setReferenceClass(com.its.tabs.tpc.layers.dal.entity.toplink.TLEntityPCDAO.class);
entitesMapping.useTransparentCollection();
entitesMapping.useCollectionClass(org.eclipse.persistence.indirection.IndirectList.class);
entitesMapping.addTargetForeignKeyFieldName("TPC_ENTITIES.PARENT_ENTITY_ID", "TPC_ENTITIES.ENTITY_ID");
descriptor.addMapping(entitesMapping);
OneToManyMapping entityattributesMapping = new OneToManyMapping();
entityattributesMapping.setAttributeName("entityattributes");
entityattributesMapping.setReferenceClass(com.its.tabs.tpc.layers.dal.entityattributes.toplink.TLEntityAttributesDAO.class);
entityattributesMapping.useTransparentCollection();
entityattributesMapping.useCollectionClass(org.eclipse.persistence.indirection.IndirectList.class);
entityattributesMapping.addTargetForeignKeyFieldName("TPC_ENTITY_ATTRIBUTES.ENTITY_ID", "TPC_ENTITIES.ENTITY_ID");
descriptor.addMapping(entityattributesMapping);
OneToOneMapping entityLevelIdMapping = new OneToOneMapping();
entityLevelIdMapping.setAttributeName("levels");
entityLevelIdMapping.setReferenceClass(TLLevelsDAO.class);
entityLevelIdMapping.useProxyIndirection();
entityLevelIdMapping.readOnly();
entityLevelIdMapping.addForeignKeyFieldName("TPC_ENTITIES.LEVEL_ID", "TPC_LEVELS.LEVEL_ID");
descriptor.addMapping(entityLevelIdMapping);
OneToOneMapping entityLookupIdMapping = new OneToOneMapping();
entityLookupIdMapping.setAttributeName("lookups");
entityLookupIdMapping.setReferenceClass(TLLookupDAO.class);
entityLookupIdMapping.useProxyIndirection();
entityLookupIdMapping.readOnly();
entityLookupIdMapping.addForeignKeyFieldName("TPC_ENTITIES.LOOKUP_ID", "TPC_LOOKUP.LOOKUP_ID");
descriptor.addMapping(entityLookupIdMapping);
return descriptor;
code for accessing this object:
public List <EntityPCEntity> findAllEntities() throws DatabaseException {
List<EntityPCEntity> entityList = new ArrayList<EntityPCEntity>();
entityList = (List<EntityPCEntity>)this.getTABSEntityManagerFinder().getEclipseLinkAdapter().readMultipleDAOs(TLEntityPCDAO.class);
return entityList;
Exception stack
javax.ejb.EJBException: java.lang.StackOverflowError
at com.evermind.server.ejb.EJBUtils.getLocalUserException(EJBUtils.java:317)
at com.evermind.server.ejb.interceptor.system.AbstractTxInterceptor.convertAndHandleMethodException(AbstractTxInterceptor.java:67)
at com.evermind.server.ejb.interceptor.system.TxRequiredInterceptor.invoke(TxRequiredInterceptor.java:52)
at com.evermind.server.ejb.interceptor.InvocationContextImpl.proceed(InvocationContextImpl.java:119)
at com.evermind.server.ejb.interceptor.system.DMSInterceptor.invoke(DMSInterceptor.java:52)
at com.evermind.server.ejb.InvocationContextPool.invoke(InvocationContextPool.java:55)
at com.evermind.server.ejb.StatelessSessionEJBObject.OC4J_invokeMethod(StatelessSessionEJBObject.java:87)
at TreeLoaderEJB_LocalProxy_3ggekch.findAllEntities(Unknown Source)
at com.its.tabs.tpc.layers.biz.TPCBusinessDelegate.findAllEntities(TPCBusinessDelegate.java:778)
at com.its.tabs.tpc.web.common.beans.tree.TpcTree.init(TpcTree.java:144)
at com.its.tabs.tpc.web.common.beans.tree.TpcTree.<init>(TpcTree.java:97)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at org.apache.myfaces.shared_impl.util.ClassUtils.newInstance(ClassUtils.java:277)
at org.apache.myfaces.shared_impl.util.ClassUtils.newInstance(ClassUtils.java:268)
at org.apache.myfaces.config.ManagedBeanBuilder.buildManagedBean(ManagedBeanBuilder.java:49)
at org.apache.myfaces.el.VariableResolverImpl.resolveVariable(VariableResolverImpl.java:314)
at org.apache.myfaces.el.ValueBindingImpl$ELVariableResolver.resolveVariable(ValueBindingImpl.java:570)
at org.apache.commons.el.NamedValue.evaluate(NamedValue.java:124)
at org.apache.commons.el.ComplexValue.evaluate(ComplexValue.java:140)
at org.apache.myfaces.el.ValueBindingImpl.getValue(ValueBindingImpl.java:386)
at javax.faces.component.UIOutput.getValue(UIOutput.java:80)
at org.apache.myfaces.shared_impl.renderkit.RendererUtils.getStringValue(RendererUtils.java:223)
at org.apache.myfaces.shared_impl.renderkit.html.HtmlTextRendererBase.renderOutput(HtmlTextRendererBase.java:69)
at org.apache.myfaces.shared_impl.renderkit.html.HtmlTextRendererBase.encodeEnd(HtmlTextRendererBase.java:57)
at javax.faces.component.UIComponentBase.encodeEnd(UIComponentBase.java:539)
at javax.faces.webapp.UIComponentTag.encodeEnd(UIComponentTag.java:498)
at javax.faces.webapp.UIComponentTag.doEndTag(UIComponentTag.java:366)
at _index._jspService(_index.java:431)
at com.orionserver.http.OrionHttpJspPage.service(OrionHttpJspPage.java:59)
at oracle.jsp.runtimev2.JspPageTable.service(JspPageTable.java:453)
at oracle.jsp.runtimev2.JspServlet.internalService(JspServlet.java:591)
at oracle.jsp.runtimev2.JspServlet.service(JspServlet.java:515)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
at com.evermind.server.http.ServletRequestDispatcher.invoke(ServletRequestDispatcher.java:711)
at com.evermind.server.http.ServletRequestDispatcher.forwardInternal(ServletRequestDispatcher.java:368)
at com.evermind.server.http.ServletRequestDispatcher.unprivileged_forward(ServletRequestDispatcher.java:287)
at com.evermind.server.http.ServletRequestDispatcher.access$100(ServletRequestDispatcher.java:50)
at com.evermind.server.http.ServletRequestDispatcher$2.oc4jRun(ServletRequestDispatcher.java:193)
at oracle.oc4j.security.OC4JSecurity.doPrivileged(OC4JSecurity.java:283)
at com.evermind.server.http.ServletRequestDispatcher.forward(ServletRequestDispatcher.java:198)
at org.apache.myfaces.context.servlet.ServletExternalContextImpl.dispatch(ServletExternalContextImpl.java:419)
at org.apache.myfaces.application.jsp.JspViewHandlerImpl.renderView(JspViewHandlerImpl.java:211)
at org.ajax4jsf.framework.ViewHandlerWrapper.renderView(ViewHandlerWrapper.java:101)
at org.ajax4jsf.framework.ajax.AjaxViewHandler.renderView(AjaxViewHandler.java:222)
at org.apache.myfaces.lifecycle.RenderResponseExecutor.execute(RenderResponseExecutor.java:41)
at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:132)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:140)
at com.evermind.server.http.ResourceFilterChain.doFilter(ResourceFilterChain.java:64)
at org.apache.myfaces.webapp.filter.ExtensionsFilter.doFilter(ExtensionsFilter.java:100)
at com.evermind.server.http.EvermindFilterChain.doFilter(EvermindFilterChain.java:15)
at org.apache.myfaces.webapp.filter.ExtensionsFilter.doFilter(ExtensionsFilter.java:147)
at com.evermind.server.http.EvermindFilterChain.doFilter(EvermindFilterChain.java:17)
at org.ajax4jsf.framework.ajax.xmlfilter.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:75)
at org.ajax4jsf.framework.ajax.xmlfilter.BaseFilter.doFilter(BaseFilter.java:213)
at com.evermind.server.http.ServletRequestDispatcher.invoke(ServletRequestDispatcher.java:619)
at com.evermind.server.http.HttpRequestHandler.doProcessRequest(HttpRequestHandler.java:866)
at com.evermind.server.http.HttpRequestHandler.processRequest(HttpRequestHandler.java:448)
at com.evermind.server.http.AJPRequestHandler.run(AJPRequestHandler.java:306)
at com.evermind.server.http.AJPRequestHandler.run(AJPRequestHandler.java:194)
at oracle.oc4j.network.ServerSocketReadHandler$SafeRunnable.run(ServerSocketReadHandler.java:260)
at oracle.oc4j.network.ServerSocketAcceptHandler.procClientSocket(ServerSocketAcceptHandler.java:239)
at oracle.oc4j.network.ServerSocketAcceptHandler.access$700(ServerSocketAcceptHandler.java:34)
at oracle.oc4j.network.ServerSocketAcceptHandler$AcceptHandlerHorse.run(ServerSocketAcceptHandler.java:880)
at com.evermind.util.ReleasableResourcePooledExecutor$MyWorker.run(ReleasableResourcePooledExecutor.java:303)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.StackOverflowError
logs and opmn configurations are attached
appreciate your help as i'm new to eclipse link
FUDForum. Page generated in 0.02017 seconds
