Home » Modeling » EMF » [CDO] starnge error after aproximately 200 requests to db
[CDO] starnge error after aproximately 200 requests to db [message #1386522] Wed, 18 June 2014 06:12 Go to next message
Arek Kowal is currently offline Arek KowalFriend
After approximately 200 requests to db I have error (practically all the time):
java.lang.RuntimeException: org.apache.cxf.interceptor.Fault: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Channel registration timeout after 10000 milliseconds
at org.apache.cxf.interceptor.AbstractFaultChainInitiatorObserver.onMessage(AbstractFaultChainInitiatorObserver.java:116)
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:322)
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121)
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:237)
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:214)
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:194)
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:131)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:266)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:191)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:242)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
Caused by: org.apache.cxf.interceptor.Fault: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Channel registration timeout after 10000 milliseconds
at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:162)
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:128)
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:165)
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:89)
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:57)
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:93)
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:262)
... 31 more
Caused by: org.eclipse.net4j.channel.ChannelException: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Channel registration timeout after 10000 milliseconds
at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:174)
at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol.java:150)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:212)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:237)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:139)
at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
at org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:359)
at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurationImpl.openNet4jSession(CDONet4jSessionConfigurationImpl.java:104)
at sun.reflect.GeneratedMethodAccessor30.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:180)
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96)
... 36 more
Caused by: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Channel registration timeout after 10000 milliseconds
at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:165)
... 60 more
Caused by: org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration timeout after 10,000 milliseconds
at org.eclipse.net4j.internal.tcp.ControlChannel.registerChannel(ControlChannel.java:102)
at org.eclipse.net4j.internal.tcp.TCPConnector.registerChannelWithPeer(TCPConnector.java:360)
at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:159)
... 60 more
Could you investigate about this problem ?
Re: [CDO] starnge error after aproximately 200 requests to db [message #1386539 is a reply to message #1386522] Wed, 18 June 2014 08:08 Go to previous messageGo to next message
Per Sterner is currently offline Per SternerFriend
Member
I think the JVM has run nearly out of memory. Perhaps some used instances needs to be cleaned up?
[Updated on: Wed, 18 June 2014 08:08]
Report message to a moderator
Re: [CDO] starnge error after aproximately 200 requests to db [message #1386542 is a reply to message #1386539] Wed, 18 June 2014 08:14 Go to previous messageGo to next message
Member
Are you opening one CDOSession for each connection? You can use the CDOSession and for example a CDOView globally which are provided by (you by) an OSGI-Service.
Re: [CDO] starnge error after aproximately 200 requests to db [message #1386547 is a reply to message #1386542] Wed, 18 June 2014 08:41 Go to previous messageGo to next message
Yes, we are using CDOSession for each connection, but we close this session after each request...
Pseudo-code of our request:
1) Opening session
2) Opening transaction
3) Request to db
4) Rollback of transaction (this is a workaround preventing some odd CDO behavior, when entities were magically detached and as a result removed from the database (!!!) )
5) Session closing.
What do you think about this method of querying db ?
Re: [CDO] starnge error after aproximately 200 requests to db [message #1386559 is a reply to message #1386547] Wed, 18 June 2014 09:23 Go to previous messageGo to next message
Member
I only describe my experience, perhaps there are also flaws.
> 1) Opening session
The Session should be reused, otherwise the (local) caching features from CDO are not used.
Try the CDOView with passive updates disabled.
> 3) Request to db
Ok Smile
You can configure that a CDOView doesn't receive Passive Updates. It should work. For testing you don't need to rollback the transaction if it is closed and not reused.
> 5) Session closing.
See 1)
Re: [CDO] starnge error after aproximately 200 requests to db [message #1386920 is a reply to message #1386559] Mon, 23 June 2014 06:34 Go to previous messageGo to next message
ok, thank you
I changed my code according to your suggestions, but this problem still exist...
public void executeSTH()
CDOSession activeSession = cdoSP.getActiveSess();
CDOView view = activeSess.openView();
executeIn(view);
public void executeIn(CDOView view)
try {
String pSQL = "select * ...");
CDOQuery query = view.createQuery("sql", pSQL);
result.addAll(query.getResult(A.class));
} catch (Exception ex) {
System.out.println("!!!");
Re: [CDO] starnge error after aproximately 200 requests to db [message #1386929 is a reply to message #1386920] Mon, 23 June 2014 07:21 Go to previous messageGo to next message
Member
Nobody closes the CDOView?
The User who processes the result should open and close the view. (But it would be better if the view could be used globally)
[Updated on: Mon, 23 June 2014 07:21]
Re: [CDO] starnge error after aproximately 200 requests to db [message #1387102 is a reply to message #1386929] Tue, 24 June 2014 06:52 Go to previous messageGo to next message
I added closing for CDOView. But problem still exist.
In this case I run my apps on virtual machine with Windows (earlier run - virtual machine with linux)
On Windows I have additional error:
Caused by: java.lang.OutOfMemoryError: unable to create new native thread
at java.lang.Thread.start0(Native Method)
at java.lang.Thread.start(Unknown Source)
at org.eclipse.internal.net4j.buffer.BufferPool.doActivate(BufferPool.java:177)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
at org.eclipse.net4j.util.container.ManagedContainer.activateElement(ManagedContainer.java:340)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:325)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:301)
at org.eclipse.net4j.TransportInjector.getBufferProvider(TransportInjector.java:102)
at org.eclipse.net4j.TransportInjector.processConnector(TransportInjector.java:83)
at org.eclipse.net4j.TransportInjector.process(TransportInjector.java:51)
at org.eclipse.net4j.util.container.ManagedContainer.postProcessElement(ManagedContainer.java:570)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:321)
at org.eclipse.net4j.tcp.TCPUtil.getConnector(TCPUtil.java:65)
at sun.reflect.GeneratedMethodAccessor32.invoke(Unknown Source)
... 37 more
Re: [CDO] starnge error after aproximately 200 requests to db [message #1387132 is a reply to message #1387102] Tue, 24 June 2014 10:25 Go to previous messageGo to next message
I found problem and I described this issue in this post: https://www.eclipse.org/forums/index.php/m/1387131/#msg_1387131
Re: [CDO] starnge error after aproximately 200 requests to db [message #1388405 is a reply to message #1387132] Thu, 26 June 2014 11:48 Go to previous message
Member
I have done a little testing with opening many many CDOView parallel. I could not reproduce your situation. (I am using CDO with Postgres and H2 under linux and windows)
The best way would be, if you could wrap up the problem in a Unittest for CDO.
Previous Topic:Add GenModel option for platform scheme-aware URIs in XXXEditor.doSave()
Next Topic:[CDO] DBStore postresql
Current Time: Mon Jul 13 22:41:06 GMT 2020
Powered by FUDForum. Page generated in 0.02052 seconds
