Home » Modeling » EMF » Custom validation for ID attribute
Custom validation for ID attribute [message #1386504] Wed, 18 June 2014 00:02 Go to next message
Agustin Vosou is currently offline Agustin VosouFriend
Hi everyone,
I am trying to customize the validation for every ID attribute (of every EClass) but I couldn't find the correct way to do it. I need this in order to validate the use of illegal characters like "$", "&", " " or "#".
Class A
  Att1 : ID = true
  Att2 : ID = false
Class B
  Att3 : ID = true
  Att4 : ID = false
In the above example, Att1 (Class A) and Att3 (Class B) should be validated with the custom validator.
Is this possible to do? Or anyone knows any way to do this or a better approach than custom validation?
Thanks in advance!
Re: Custom validation for ID attribute [message #1386526 is a reply to message #1386504] Wed, 18 June 2014 06:36 Go to previous messageGo to next message
Agustin,
You can define your own EDataType with a constraint:
http://help.eclipse.org/kepler/index.jsp?topic=/org.eclipse.emf.doc/references/overview/EMF.Validation.html
You could also make use of an extended metadata annotation as created by
org.eclipse.emf.ecore.util.ExtendedMetaData.setPatternFacet(EDataType,
List<String>) to define the pattern of valid IDs on your EDataType (so
that you don't have to write the constraint logic yourself).
On 18/06/2014 2:02 AM, Agustin Vosou wrote:
> Hi everyone,
> " " or "#".
> Class A
> Att1 : ID = true
> Att2 : ID = false
> Class B
> Att3 : ID = true
> Att4 : ID = false
> Thanks in advance!
Re: Custom validation for ID attribute [message #1386527 is a reply to message #1386526] Wed, 18 June 2014 06:37 Go to previous messageGo to next message
Or perhaps just use the ID EDataType from XMLType.ecore if that data
type's constraints match your needs.
On 18/06/2014 8:36 AM, Ed Merks wrote:
> Agustin,
> by
>> Hi everyone,
>> "&", " " or "#".
>> Class A
>> Att1 : ID = true
>> Att2 : ID = false
>> Class B
>> Att3 : ID = true
>> Att4 : ID = false
>> Thanks in advance!
Re: Custom validation for ID attribute [message #1386635 is a reply to message #1386527] Wed, 18 June 2014 22:46 Go to previous messageGo to next message
Thank you Ed,
I think I am going for the second option and test if that data type's constraints fit my needs.
Agustin.
Re: Custom validation for ID attribute [message #1387075 is a reply to message #1386635] Mon, 23 June 2014 22:58 Go to previous messageGo to next message
After testing the ID EDataType from XMLType.ecore and it's constraints, I decided to go for the first option Ed gave me... So I've defined the following EDataType:
  <eClassifiers xsi:type="ecore:EDataType" name="ID" instanceClassName="java.lang.String">
    <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
      <details key="name" value="ID"/>
      <details key="baseType" value="java.lang.String"/>
      <details key="pattern" value="[a-zA-Z0-9]+"/>
    </eAnnotations>
  </eClassifiers>
As you can see, I've used an ExtendedMetadata annotation to define the accepted values with a pattern.
Thank you very much for your help and time.
Agustin.
Re: Custom validation for ID attribute [message #1387088 is a reply to message #1387075] Tue, 24 June 2014 04:58 Go to previous message
Agustin,
The pattern annotation is quite useful. Thanks for sharing your results.
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> Regards,
> Agustin.
Previous Topic:[CDO] Collection returns contains = false for Query loaded object.
Next Topic:Command grouping in CommandStack
Current Time: Wed Jul 08 01:42:36 GMT 2020
Powered by FUDForum. Page generated in 0.02252 seconds
