Re: Error Help [message #1386507 is a reply to message #1386360] |
Wed, 18 June 2014 02:34 |
On 06/17/2014 06:19 AM, Kyle R wrote:
> I am using Eclipse and cannot figure out how to correct the following
> error that occurs on all new projects that are created.
> "Error retrieving parent for item: No resource found that matches the
> given name 'Theme.AppCompat.Light'."
> This error appears to stem from <style name="AppBaseTheme"
> parent="Theme.AppCompat.Light"> in the styles.xml folders.
> The other error is "R cannot be resolved to a variable"
> I have spent all day trying to figure this out. I have re-installed the
> ADT bundle 22.6.3, Eclipse 4.3.2, Java JRE and JDK.
> Many posts pointed toward android-support-v7-appcompt.jar not being in
> the libs folder and yes that did solve some of the errors that I had.
> Any information would be much appreciated.
What Eric said.
However, I will throw you one bone since I happen to know what you're
talking about.
http://www.javahotchocolate.com/tutorials/android.html#r-java
FUDForum. Page generated in 0.08058 seconds
