Re: Generate includes for types referenced in body of inferred methods [message #1386153 is a reply to message #1386150] |
Fri, 13 June 2014 17:15 |
Hmmm it looks like all api for that is hidden. can you please file a enhancement request for better api (e.g. one that gives access to importmanager
as a workaround:
body = [
append(entity.newTypeRef(List, entity.newTypeRef(String)).type)
append('''
featureNames = new ''')
append(entity.newTypeRef(ArrayList, entity.newTypeRef(String)).type)
.append('''();
«FOR f:entity.features»
featureNames.add("«f.name»");
«ENDFOR»
return featureNames.toArray(new String[featureNames.size()]);
Twitter : @chrdietrich
Re: Generate includes for types referenced in body of inferred methods [message #1386154 is a reply to message #1386153] |
Fri, 13 June 2014 17:26 |
hmmm actually it is not working but this is
package org.eclipse.xtext.example.domainmodel.jvmmodel
import com.google.inject.Inject
import java.util.ArrayList
import java.util.List
import org.eclipse.xtext.common.types.JvmField
import org.eclipse.xtext.example.domainmodel.domainmodel.Entity
import org.eclipse.xtext.example.domainmodel.domainmodel.Operation
import org.eclipse.xtext.example.domainmodel.domainmodel.Property
import org.eclipse.xtext.naming.IQualifiedNameProvider
import org.eclipse.xtext.xbase.jvmmodel.AbstractModelInferrer
import org.eclipse.xtext.xbase.jvmmodel.IJvmDeclaredTypeAcceptor
import org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder
import org.eclipse.xtext.xbase.lib.Procedures.Procedure1
import org.eclipse.xtext.xbase.typesystem.legacy.StandardTypeReferenceOwner
import org.eclipse.xtext.xbase.typesystem.references.OwnedConverter
import org.eclipse.xtext.xbase.typesystem.util.CommonTypeComputationServices
class DomainmodelJvmModelInferrer extends AbstractModelInferrer {
@Inject extension JvmTypesBuilder
@Inject extension IQualifiedNameProvider
@Inject
private CommonTypeComputationServices services;
def dispatch infer(Entity entity, IJvmDeclaredTypeAcceptor acceptor, boolean prelinkingPhase) {
acceptor.accept(
entity.toClass( entity.fullyQualifiedName )
).initializeLater [
members += entity.toMethod("getFeatures", entity.newTypeRef(String).addArrayTypeDimension) [
val that = it
body = [
val StandardTypeReferenceOwner owner = new StandardTypeReferenceOwner(services, that);
val OwnedConverter converter = new OwnedConverter(owner);
var t1 = converter.toLightweightReference(entity.newTypeRef(List, entity.newTypeRef(String)))
var t2 = converter.toLightweightReference(entity.newTypeRef(ArrayList, entity.newTypeRef(String)))
append(t1)
append(''' featureNames = new ''')
append(t2)
.append('''();
«ENDFOR»
documentation = entity.documentation
if (entity.superType != null)
superTypes += entity.superType.cloneWithProxies
val procedure = entity.newTypeRef(Procedure1, it.newTypeRef())
members += entity.toConstructor() []
parameters += entity.toParameter("initializer", procedure)
body = '''initializer.apply(this);'''
val fields = <JvmField>newArrayList()
for ( f : entity.features ) {
switch f {
Property : {
val field = f.toField(f.name, f.type)
fields += field
members += field
members += f.toGetter(f.name, f.type)
members += f.toSetter(f.name, f.type)
Operation : {
members += f.toMethod(f.name, f.type ?: inferredType) [
documentation = f.documentation
for (p : f.params) {
parameters += p.toParameter(p.name, p.parameterType)
body = f.body
members += entity.toToStringMethod(it)
Re: Generate includes for types referenced in body of inferred methods [message #1728105 is a reply to message #1728102] |
Thu, 31 March 2016 07:17 |
Larry LeBron Messages: 124 Registered: October 2015 |
Hmm, I'm not sure if I fully understand.
Are you saying I should use a StringConcatenationClient instead of using a StringBuilder for appending the bits of my method body?
I tried subclassing StringConcatenationClient to do this, but it does not offer the same interface as StringBuilder. There is an appendTo method, but it's not clear how to set things up to work properly.
Just to clarify, my current pattern is:
val StringBuilder methodBodyBuilder = new StringBuilder
// iterate through EObjects, appending Strings to the methodBodyBuilder
// e.g. which I would want to import "Type"
methodBodyBuilder.append('''«Type».method(«args»)'''
// Once this is all done, build the method, using the StringBuilder:
source.toMethod(methodName, typeRef(boolean)) [
body =
«methodBodyBuilder.toString»
return false;
I also tried just dumping my StringBuilder's contents into a StringConcatenationClient, but that did not cause the type to be imported either.
Thanks yet again!
FUDForum. Page generated in 0.04061 seconds
