Re: Unable to create first entity in emtpy table [message #1386100 is a reply to message #1386063] |
Fri, 13 June 2014 12:30 |
Normally, you should have a create tool that appears in the toolbar.
I attached a simple example project.
Laurent
Le 13/06/2014 11:57, Wilbert Alberts a écrit :
> This is probably a silly question.
> The root element in my metamodel is Model and it contains Interface entities. I want to represent the Interface entities in a table (and add new ones). I added an InterfaceLine and CreateLine tools to the description.
> However, I am unable to create the first interface. If my model already contains an interface (created by some other means), then that interface shows up and I can add additional ones by right clicking that interface and select the proper tool.
> How or where should I create the tool that allows me to create an Interface in an otherwise empty model?
> I attached a screenshot showing the organisation of VSP description.
> Greetings,
> Wilbert.
Laurent Redor - Obeo
FUDForum. Page generated in 0.03083 seconds
